fckawhipboughtabanshee Posted March 30, 2018 Author Report Posted March 30, 2018 The top plate can stay. However, the little half moon retainer below it needs to come out. Tried using a small impact driver or even a dead blow screw driver?Thanks for the reply man tryin to get these cases split asap haha but I used an impact drill was able to break loose the right screwBut the left screw it's kind of grinding against the gear closest to it and the clutch spacer in the middle not to much but it's till making contact here n there should it be alright or should i look into new ones ? I wasn't able to break that one so I'll spray some blaster and try that one again later Thanks againSent from my iPad using Tapatalk Quote
Ayesully810 Posted March 30, 2018 Report Posted March 30, 2018 (edited) take a small cutting wheel and cut a nice cut in it and bang it loose with an impact driver and dead blow. I took apart a motor that sat for 20 plus years and i had to do that on almost every screw on the side covers. it will work Edited March 30, 2018 by Ayesully810 Quote
Keno Posted March 30, 2018 Report Posted March 30, 2018 BTW, this is the type of impact driver you want. https://www.amazon.com/dp/B000NPPATS/ref=cm_sw_r_cp_apa_TbQVAbXDZZ371 Quote
fckawhipboughtabanshee Posted March 30, 2018 Author Report Posted March 30, 2018 Ahh okay I saw that on a vid just wasn't sure the name ha gotta pay attention thanks a lot for the info guys hopefully by the end of weekend I should have cases split.. By the way anyone know the size of that top screw or where I could get one I stripped the head so I'll do wat sully says but I looked on FAST and i seem to only find the plate stopper screws which seemed to be a little bigger than the top screws I could be wrong tho.. figured I'd replace that top right one since I was able to break loose the left top screw without damaging..Sent from my iPad using Tapatalk Quote
fckawhipboughtabanshee Posted April 8, 2018 Author Report Posted April 8, 2018 Finally got the damn thing splitSent from my iPad using Tapatalk Quote
fckawhipboughtabanshee Posted April 8, 2018 Author Report Posted April 8, 2018 Is this OEM crank if so you guys think it's worth rebuilding for next time or just getting new ones is the best route?Sent from my iPad using Tapatalk Quote
fckawhipboughtabanshee Posted April 8, 2018 Author Report Posted April 8, 2018 Last question , I'm cleaning the cases with citrol is that okay to use and can I leave the shift drum and forks in there when cleaning it and spraying it down with water after ? The manual says take it out but if I don't got to I'll leave them in . Or should i take the drum out and forks? Thanks guysSent from my iPad using Tapatalk Quote
fckawhipboughtabanshee Posted April 10, 2018 Author Report Posted April 10, 2018 (edited) Hey guys.. so went to a shop here in AZ to see how much it would be to weld my crank and to bore my cylinders . The guy said that for the amount of power I'm throwing down I won't need that weld unless I'm going over 9,000 rpms? Any inputs on that he said he'd charged me 80 for the weld if I wanted to do it which I told him I did for insurance but let me know what you guys think . As for the jugs he said he would bore them out 60 each ? Than I started talking to the guy about how far along I was on the project and he ended up letting me know he would be able to assemble the motor for 200 and sync the carbs for another 100 . I ended up showing him how my cases looked, trans ,all that good stuff n he said to clean and make sure everything 100% on motor and carbs he'll charge $400 how does that sound? But doesn't include clutch I'll have to end up getting a new one on that so basically I just bolt the motor in and connect what need to be conneted and start her up he said he'd do the leak down n all that. What do you guys think? This bike will be done by the end of week back on the streets of AZ Edited April 10, 2018 by fckawhipboughtabanshee Quote
ginger Posted April 10, 2018 Report Posted April 10, 2018 weld the crank. it sounds like he isnt a high power banshee guy if he isnt recommending that. Quote
camp0429 Posted April 10, 2018 Report Posted April 10, 2018 ^^That and also save yourself the money of somebody else putting it together and just do it yourself. Between a Clymers and this site there is more than enough information. There is even a step by step walk through on a lower end assembly somewhere on here. There really is not much to it. If you do it yourself you will know what all is involved. One more thing is I am not knocking the shop you talked to by no means, but there is too many horror stories out there of "shops" screwing people over. If you do it yourself you will know it's done right. Quote
fckawhipboughtabanshee Posted April 10, 2018 Author Report Posted April 10, 2018 (edited) Shit .. I should've just went with that option but it was all a last minute thing and this guy already has 300 on hand so I figure eff it... live and learn.. and trust me I know lol I've seen so many people say weld it and I keep insisting for that but for some reason this guy just kept saying I didn't need it lol I'm paying so idk what the problem would be ha he just texted me right now saying I'm needing a clutch , 23 cc domes and Japanese Main bearings , any recommendations on if that a good size domes for they type of riding I do . Thanks for the response guys helped out a lot.. kinda sad now tho that I let go of the project like that , kinda feel sketch leaving it but we live n learn shit with the type of riding I do there will be another project in the near future and even disassembling it helped me out with the basics ahah thanks again guys. Edited April 10, 2018 by fckawhipboughtabanshee Quote
ginger Posted April 10, 2018 Report Posted April 10, 2018 i think you need to pick up your motor from the guy, and take it to a known shop that isnt going to bend you over, and will build a motor that will stay together. Quote
fckawhipboughtabanshee Posted April 10, 2018 Author Report Posted April 10, 2018 (edited) Ye man was really considering it might as well since I'm needing to order in those parts ha I can't even find 23 cc domes just 22, and ye sadly he is a known shop here in tuc nobody else works on banshees here or quads older than a 2002 or 1 I forgot what ridenow had said but he's basically the only known shop here that does banshees .. next time a go to his shop I'll show u all his projects there mean bro ... Edited April 10, 2018 by fckawhipboughtabanshee Quote
ginger Posted April 11, 2018 Report Posted April 11, 2018 i wouldnt fear shipping it to a sponsor here. where most of their business is 90% banshee Quote
