Understandable. I always go for oem when I have the money for it. A local atv shop owner I know  swears by Ricky stator parts. But only time will tell. If not going to be going oem no matter what.
10 hours ago, n2otoofast4u said:
If it's "for sure the wiring harness" they why in the fuck are you wasting your money on that other junk?
Sent from my SM-G930V using Tapatalk
he replaced everything else, that is all that is left.....
  • 2 weeks later...
  • 4 weeks later...
So I got it going finally was the stator the whole time. But I had to replace clutch push rod and bearing and adjustment screw due to friction welded itself together. And also had to replace the clutch engagement arm that gos down into case. When I replaced that arm I had to remove left carb. Put all back together and now won't start. Gets fuel, has good spark and good compression so I don't get what's going on here.
