Codyshep
Codyshep's Achievements
  1. Yes it's connected I'm so confused as to why it won't start
  2. So I got it going finally was the stator the whole time. But I had to replace clutch push rod and bearing and adjustment screw due to friction welded itself together. And also had to replace the clutch engagement arm that gos down into case. When I replaced that arm I had to remove left carb. Put all back together and now won't start. Gets fuel, has good spark and good compression so I don't get what's going on here.
  3. I got her going finally. The harness was melted near the exhaust. And the stator was completely shot.
  4. Because the other shit got fried too.thats why
  5. Yes it's for sure the wiring harness. And thank you I will do that. If these parts are shit then I will be going with oem all the time.
  6. Understandable. I always go for oem when I have the money for it. A local atv shop owner I know swears by Ricky stator parts. But only time will tell. If not going to be going oem no matter what.
  7. Ok I was thinking of doing that. But how come? Just curious
  8. Not oem I got a ricky stator stator, bronco brand igontion coil, a ricky stator cdi box, and Ricky stator race only wiring harness. Could not afford to buy oem at this moment.
  9. So I figured out that it's my wiring harness it's completely toast. Going to put new one in when it gets here. And new coil and cdi.
  10. Ok thank you
  11. Ok I will go back through and make sure they are connected together. It's just weird that I have been riding it since I bought it 3 days ago and all of a sudden it won't start now.
  12. I unplugged the on/off switch but still no spark and the key switch was removed before I bought it. I couldn't find a short anywhere. Could it be cdi box?
  13. My 2001 banshee was running fine and all of sudden just died and would not start. Checked for spark and there was no spark at all. Figured it was a bad coil so I replaced it and started first kick. Then died again and won't start any ideas? It is tors deleted.
