justin_smallwood Posted September 7, 2017 Author Report Posted September 7, 2017 Asphalt, dirt, sand?Oh...lol...strictly dirt ..Sent from my LG-D722 using Tapatalk Quote
registered user Posted September 7, 2017 Report Posted September 7, 2017 why would u put the timing at 10. makes no sense. put it at 0-4 but no higher. then get the carb tuning under control. adjust timing as needed after u get the carb sorted out. Quote
justin_smallwood Posted September 7, 2017 Author Report Posted September 7, 2017 Hmmm, you're the first person I've seen say start with 0-4 . Everyone else says start with at least 7 being on methanol.. And I just left at 10 because that's what the bike wanted when I ran pump gas. Sent from my LG-D722 using Tapatalk Quote
JTmachining Posted September 7, 2017 Report Posted September 7, 2017 why would u put the timing at 10. makes no sense. put it at 0-4 but no higher. then get the carb tuning under control. adjust timing as needed after u get the carb sorted out. Lol Quote
JTmachining Posted September 7, 2017 Report Posted September 7, 2017 Could be fuel. Could be moisture. Could be cause a lot. Make some test hits and see how it runs Quote
justin_smallwood Posted September 7, 2017 Author Report Posted September 7, 2017 Could be fuel. Could be moisture. Could be cause a lot. Make some test hits and see how it runsYeah I am this Saturday..unfortunately where I live im not able to test right after a change. Like I said I had a broken oring so hope that was causing the blow out of the pipe..I'll seeSent from my LG-D722 using Tapatalk Quote
n2otoofast4u Posted September 7, 2017 Report Posted September 7, 2017 why would u put the timing at 10. makes no sense. put it at 0-4 but no higher. then get the carb tuning under control. adjust timing as needed after u get the carb sorted out. What in the absolute fuck?Sent from my SM-G900V using Tapatalk Quote
registered user Posted September 8, 2017 Report Posted September 8, 2017 his plugs are coming out. pistons probly look like theyre jack hammered. rod bearings likely taking a severe beating. turn timing up a few more notches Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 What pilot, main, emultion, needle, power jet, what's the powerjet drilled to? What pump? What pistons are you running? What is the squish? What squish angle? What fuel petcock? Do you have a pic of the plugs? What do the fuel and timing look like on the plug? What where the carbs set up for? What size motor? And what size is your motor? Alky can be a pain when you are first learning but once you get it figured out its pretty easy and you will love it! Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 What pilot, main, emultion, needle, power jet, what's the powerjet drilled to? What pump? What pistons are you running? What is the squish? What squish angle? What fuel petcock? Do you have a pic of the plugs? What do the fuel and timing look like on the plug? What where the carbs set up for? What size motor? And what size is your motor? Alky can be a pain when you are first learning but once you get it figured out its pretty easy and you will love it! Pilot I believe is 55, dump .122 and main is 155. Not sure what the PJ is drilled to. It was set up for a 443, and I have a 421. Still is rich. Blows some fuel out the exhaust when I rev. Nothing like before though. Is some fuel blowng out normal..plug still looks new...I'll send a pic of the pump.Sent from my LG-D722 using Tapatalk Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 Are you sure the main is a 155 or has it been drilled too? If the main is a true 155 that is your deto problem right there! Are you sure it's fuel blowing out? If so have you been buying the same fuel from the same place? Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 If it was a timing issue the plug strap would be burnt and the metal around the strap (thread portion) would be blued.. jmo.. Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 Are you sure the main is a 155 or has it been drilled too? If the main is a true 155 that is your deto problem right there! Are you sure it's fuel blowing out? If so have you been buying the same fuel from the same place? What's wrong with the 155...I believe it's a true 155...I opened the carb the other day. But no, I realized today that it was coolant and fuel blowing out...I change the oring and its back to normal. But it's still blowing out more fuel then I think it should. But is that normal on methanol. Here's the pumpSent from my LG-D722 using Tapatalk Quote
Tedder Posted September 8, 2017 Report Posted September 8, 2017 21 minutes ago, JUSTWANNARACE said: Are you sure the main is a 155 or has it been drilled too? If the main is a true 155 that is your deto problem right there! Are you sure it's fuel blowing out? If so have you been buying the same fuel from the same place? ^^ Correct - If the mains aren't drilled and you're truly running 155 mains with alcohol then you'll be way to lean Quote
