JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 (edited) I don't think it's "rich" by any means or you wouldn't be backing out plugs. A true 155 is way to small and defeats the purpose of drilling the emultion to .122... Check your compression also cause 18cc domes on a cub (unless it has a really narrow squish band and the squish is really loose) is going to be high. I would also look into electrical. May not be igniting the fuel properly. Check all grounds. Grind all paint to bare metal for the ground at cdi box. And also where the coil mounts. New ngk tb05ema spark plug boots, cut the wires back 1/2" before screwing new boots on Edited September 8, 2017 by JUSTWANNARACE Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 I don't think it's "rich" by any means or you wouldn't be backing out plugs. A true 155 is way to small and defeats the purpose of drilling the emultion to .122... Check your compression also cause 18cc domes on a cub (unless it has a really narrow squish band and the squish is really loose) is going to be high. I would also look into electrical. May not be igniting the fuel properly. Check all grounds. Grind all paint to bare metal for the ground at cdi box. And also where the coil mounts. New ngk tb05ema spark plug boots, cut the wires back 1/2" before screwing new boots onIt may be drilled I'll ask the seller...and I get the boots....thanks for all the help..I'll make an updateSent from my LG-D722 using Tapatalk Quote
nastyracing Posted September 8, 2017 Report Posted September 8, 2017 I would mount the pump differently . But your blowing fuel out your pipes because needle seat is not sealing . What pump ? Need to figure out how to slow down fuel being fed to carbs . Pretty much over flowing carbs out floats also , and throwing fuel out the pipes I had this issue . Changed my seats and always take carbs apart n clean from going from gas to alky after purging. You will find bike make world of difference when you get correct volume of fuel being fed to carb. Nothing wrong w a pump just takes time to figure out . Good luck Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 11 minutes ago, nastyracing said: I would mount the pump differently . But your blowing fuel out your pipes because needle seat is not sealing . What pump ? Need to figure out how to slow down fuel being fed to carbs . Pretty much over flowing carbs out floats also , and throwing fuel out the pipes I had this issue . Changed my seats and always take carbs apart n clean from going from gas to alky after purging. You will find bike make world of difference when you get correct volume of fuel being fed to carb. Nothing wrong w a pump just takes time to figure out . Good luck Where your carbs converted to a pump, or actual pumper carbs? Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 I would mount the pump differently . But your blowing fuel out your pipes because needle seat is not sealing . What pump ? Need to figure out how to slow down fuel being fed to carbs . Pretty much over flowing carbs out floats also , and throwing fuel out the pipes I had this issue . Changed my seats and always take carbs apart n clean from going from gas to alky after purging. You will find bike make world of difference when you get correct volume of fuel being fed to carb. Nothing wrong w a pump just takes time to figure out . Good luck Did you just get a fatter needle?Sent from my LG-D722 using Tapatalk Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 Where your carbs converted to a pump, or actual pumper carbs?This I'm not sure..Sent from my LG-D722 using Tapatalk Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 Sorry that was for nastyracing Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 5 minutes ago, justin_smallwood said: This I'm not sure.. Sent from my LG-D722 using Tapatalk From your pics your are actual pumper carbs Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 From your pics your are actual pumper carbsYup...not sure how to keep the fuel from flowing so much..Sent from my LG-D722 using Tapatalk Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 Are the carbs pushing fuel out the over flows while running? Quote
justin_smallwood Posted September 8, 2017 Author Report Posted September 8, 2017 Are the carbs pushing fuel out the over flows while running?No sir...not at allSent from my LG-D722 using Tapatalk Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 Not a needle and seat issue then most likely..jmo Quote
JUSTWANNARACE Posted September 8, 2017 Report Posted September 8, 2017 But may be a float height issue Quote
n2otoofast4u Posted September 8, 2017 Report Posted September 8, 2017 Blind leading blind Sent from my SM-G900V using Tapatalk Quote
sleeper06 Posted September 8, 2017 Report Posted September 8, 2017 What size dump/main and what style power jet is in it . Were they brand new domes n orings or did you reuse them from the gas set up Quote
