Banchee Posted January 24, 2017 Report Posted January 24, 2017 Evening all. This one has me stumped and I can't find any help online or otherwise. I purchased the streamline +2 front brake line kit, the 3 piece. I have tried every angle I can think of to mount this baystad tee fitting on the stock mounting location and it's beating me. Is there a trick to this or do I need to get a spacer/collar to put behind it? I noticed the OEM tee is much thicker and sits on the ledge of the frame. Thanks for any insights! Quote
bigweav81 Posted January 24, 2017 Report Posted January 24, 2017 Post pics using tapatalk. Sent from my SM-S820L using Tapatalk Quote
Banchee Posted January 24, 2017 Author Report Posted January 24, 2017 Sent from my iPhone using Tapatalk Pro Quote
kawa110 Posted January 24, 2017 Report Posted January 24, 2017 (edited) Hmm Edited January 24, 2017 by kawa110 Quote
bluebanshee98 Posted January 24, 2017 Report Posted January 24, 2017 I never bolted mine up and I haven't had any issues Quote
trickedcarbine Posted January 24, 2017 Report Posted January 24, 2017 Put it where it likes to be and move the bars side to side to verify its happy. Zip tie Quote
Banchee Posted January 24, 2017 Author Report Posted January 24, 2017 Good ideas, thanks! I would have thought it just would have mounted in the stock location...no muss, no fuss. Quote
sleeper06 Posted January 25, 2017 Report Posted January 25, 2017 There like a generic kit, I'm never happy with the fit n finish, I usually get the 2 piece with the dbl banjo but even that has its Lil quirks 1 Quote
Scrubby Posted January 25, 2017 Report Posted January 25, 2017 I put a spacer behind mine, and attached to the front side, ill dig up some pics. I bolted it to that tab by your finger. I installed the t differently though, mc in the middle fitting, caliper on the straight through, slight twist on the tab is needed. 1 Quote
Banchee Posted January 25, 2017 Author Report Posted January 25, 2017 I put a spacer behind mine, and attached to the front side, ill dig up some pics. I bolted it to that tab by your finger. I installed the t differently though, mc in the middle fitting, caliper on the straight through, slight twist on the tab is needed. Thanks! I would love to see some pics! Quote
Banchee Posted January 25, 2017 Author Report Posted January 25, 2017 That's one helluva idea right there. Thank you! Sent from my iPhone using Tapatalk Pro Quote
trickedcarbine Posted January 25, 2017 Report Posted January 25, 2017 Dual lines FTW!^ what the silly dude said. 1 Quote
Banchee Posted January 25, 2017 Author Report Posted January 25, 2017 Are you referring to the dual line setup from the master to the tee? Sent from my iPhone using Tapatalk Pro Quote
