Need help! Trying to figure out this build. Would like to build 521cc fuel injected and turbo charged banshee. Would like to get opinions about it. My Banshee recently blew up figured I would start start over. Any input would be great.
  • Like 1
I would love to see this idea come to fruition.  If the OP has the cheddar, I would be having the manufacturer of the turbo/efi kit install it.
On a side note, does anyone have any information on the crank in the link?  Good or bad?
^^^What he said above is correct.  You won't sniff the setup for less than 20k! If I was going to go down the path you are talking, Id set aside 20k for the initial engine/turbo build, 15k for the chassis, and another 10k for setup adjustments tires, different compressors, fack you name it!!  K&Ts turbo DMX was a fucking MISSILE, and pretty fucking reliable! If you're all in, Id surely talk to them about doing the work. They can probably do a turn key deal as well. One of the problems is no chassis builder has a jig that works with all of the components so the chassis and engine/turbo combo typically get a few trips to the fab shop together. When I did mine, I spent HOURS trying to get everything to fit/balance/seal/etc.....
  • Like 1
I was hopeing to spend under 10k for the engine but if its more im willing to save up for it.
10k will cover cases, crank, cylds, and tranny. No electronics, and no turbo setup.
