Driveline Cylinder Review Dyno Run Stock Stroke T5 Pump gas stock carbs
mailman
Because certain dome shapes/profiles can perform better then others. Plus the Cool Head allows you to switch domes pretty easily, versus having a new head cut each time you wanna change it.
I stand corrected.
I guess I should've said something like, "with the exception of his cool head dome profile".
they have a ton of room for "real" porting work also.  same setup and some work inside i bet a 8-15hp increase would be easily obtainable.
and this type of motor is what they are perfect for  budget rebuild cause you just want to fucking ride already!!!!!  and then again some work inside they should perform very strongly!
