Chop the heal guard mounts on subframe, weird pipe mounts on subframe along with the stuff Tyler said. There is a tab for the tors as well that can go. Now let's see these booty pics!
stock exhaust, airbox, tail light, heel gaurds, if your running cut plastics get rid of those tabs that arent being used, keep most the gussets if its trail bike the weight reduction barely worth the strength you sacrifice
CDI mount to the front? I'm not to familiar with this modification. Advantages?
Just a cleaner install mostly. I don't like wires running to the back of the bike.
Plus, my wiring harness is about 10" long.
What do you use to remote your CDI to the front? JDS?
I either cut the whole bracket off the rear or I use 6mm coupling nuts to build a mount.
