willaduncan Posted May 27, 2015 Report Posted May 27, 2015 (edited) I bet your bottom end seals are shot, is there any fuel in your trans oil? Sent from my iPhone using Tapatalk Edited May 27, 2015 by willaduncan Quote
Ljj Posted May 28, 2015 Report Posted May 28, 2015 (edited) Reading your post I feel ya man, having same problem with my shee really sucks. 2 weeks and I'm still tuning. Went from 27.5 to 290-240 jets with dg pipes Thoe(came with bike) and still no idle Edited May 28, 2015 by Ljj Quote
Darkblade Posted June 13, 2015 Report Posted June 13, 2015 (edited) hey i have a stage 3 port job with a cool head and 21 cc domes 65mm wiseco 795 pistons vf4 reeds uni pod filters fmf gnarly pipes with power core 2 silencers runnin a hotrods 4mil long rod crank and stock carbs my areas temperature is imbetween 75 and 95 degrees my elevation is between 600 and 850 ft what main jet and pilot jet size should i use and what should my needle jet be set on thanks Edited June 13, 2015 by Darkblade Quote
bigweav81 Posted June 13, 2015 Report Posted June 13, 2015 hey i have a stage 3 port job with a cool head and 21 cc domes 65mm wiseco 795 pistons vf4 reeds uni pod filters fmf gnarly pipes with power core 2 silencers runnin a hotrods 4mil long rod crank and stock carbs my areas temperature is imbetween 75 and 95 degrees my elevation is between 600 and 850 ft what main jet and pilot jet size should i use and what should my needle jet be set on thanksWho did the stage 3 port job? sent from yo mammy house Quote
Darkblade Posted June 13, 2015 Report Posted June 13, 2015 (edited) Who did the stage 3 port job? sent from yo mammy house not sure i bought them off of ebay but i think it was done by jeff at fast racing atleast thats what the previous owner said Edited June 13, 2015 by Darkblade Quote
willaduncan Posted June 30, 2015 Report Posted June 30, 2015 Haven't heard "stage x" port job in a while, sounds like you got a case of bull shit seller and gullible buyer goin on Sent from my iPhone using Tapatalk Quote
markjohnson151 Posted July 10, 2015 Author Report Posted July 10, 2015 Ok got rid of tors not it will idle sounds pretty good but i noticed that the right cylinder is pushing more exhaust then the left. Keep in mind this is my first banshee so I'm experiencing this all for the first time. What can I do in order to even it out to where its right. Thanks Quote
trickedcarbine Posted July 10, 2015 Report Posted July 10, 2015 Sync carbs. There are YouTube videos with a simple break down as well as a thread in the technical section. Quote
