I wish I knew. Hp2000 gave me some advice. So I'm going to go with a one step colder plug and check the compression after I throw in a new o-ring.
Well you need a new dome. I wouldn't bother trying new o rings.
Sent from my SAMSUNG-SM-G890A using Tapatalk
How is changing a beadlock wheel out easier than a non beadlocks wheel? You need a bead breaker for one side anyway, so it would be WAY faster to pop the bead off both than take about 20 bolts out of oe side and have to use a bead breaker on the other side anyway.
You guys obviously don't change tires enough.
haha you seem to be the only one that thinks it's faster with a non beadlock wheel. Taking the bolts off takes literally if even a minute you then flip it over throw it on the bead breaker and it's off in another minute. Throw the new one on and screw the bead back on..literally takes 5 min at most and you don't have to worry about damaging the wheels with spoons. Edited by Sheedawg28
haha you seem to be the only one that thinks it's faster with a non beadlock wheel. Taking the bolts off takes literally if even a minute you then flip it over throw it on the bead breaker and it's off in another minute. Throw the new one on and screw the bead back on..literally takes 5 no tires at most and you don't have to worry about damaging the wheels with spoons.
He's trolling you.
So your saying to get new domes and I should be fine? It is slightly dinged right where t happened but on the outside portion if you look closely. I dropped that one ha.
Oh yeah. Those spots that the dome is chipped is is a weak point. It's only o ring holding back the coolant/combustion.
Also throw a straight edge across the head cylinders too.
When you throw on the head if you want to be super anal about it, loosen the cylinders then tq the head.
But that's why I say throw a straight edge across the cylinders now.
Gotcha..I'll replace them also and do the rest hopefully the last time in a while I'll have to replace one. It's getting old.
On a perfect say I can change a tire in 15 minutes. You are claiming you can change one on a beadlock wheel in less time than it takes your sister to drink a beer?
Pop the bead off the inside with a drill/driver those bolts come off quicker than you can spoon one side off, swap tires and bolt them back in. We've had tire changing contests in between my group of buddies when we're had nothing to do Saturday nights at the track waiting for Sunday mornings event. So it's not what I claim it's what I know. Just like the last argument you tried starting up on here and didn't make sense, this ones right along the lines.
