I have a hard time starting my yamaha banshee when it is cold. How much throtle do you give it? I pull the choke half way out and very lightly push the gas with the clutch pulled in. Do I need to set the parking brake to start my motor.
what i do is put it in nutral and pull choke out all the way and kick it with no gas at all i dont know if yours will do this but mine will start to idle and i just give it a little gas to keep it runnin in tell its warm enough to idle
Turn gas on, let it set for a few to let the gas run through everything, do 4-5 SLOW "priming" kicks, the pull the choke out 1/2 way and give it hell. Should start w/ in 2-3 kicks.
Mike
Pull choke out fully, no gas, and kick until it starts....Giving it gas will defeat the purpose of the choke..
That's my method to. By leaving the throttle closed, the vacuum created by the motor stays in the carbs to pull the fuel in. If you open the throttle the vacuum escapes through the air filter before it pulls the fuel in.
Indeed. General consensus is on almost every manual choke system is full choke untill it at least fires. And then half choke or less than full choke from there on out. Way to tell the difference if it needs half, or "less than full" is to decipher if it is in fact a choke system, or a setup like a banshee where it is a "fuel accelerator circuit". It doesn't "choke" the carbs of air to pull more fuel, it draws fuel DIRECT from the bowl. This is why there is an extra tube in the left carb bowl. That's where it draws the fuel from. And why there is a choke tube. Mine starts on the 2-3 kick, and I immediately put it to half choke if it is really cold, and off if it not really cold. Depends how it is runnign once it fires up. It shouldn't be too hard to fire up, as long as the systems are operating properly. If it is hard to fire up, than maybe you have the wrong bowl on the wrong carb...
i pull the choke out all the way give it 5-7 primer kicks then it starts the i go to half choke then to none and hold the gas just tiny bit.....then when my temp gague says 100 i take off....slow untill 120 then i can go
shane
Does it do anygood to chop the throttle a few times before kicking it, sorda to shoot fuel into the motor? Also, if it requires more then a few kicks to get it going, do you need to go up on the pilot jet or down?
  • 9 years later...
Really, another how to start my bike thread. Well...... I just crack the throttle about half and give it a few real slow kicks with the choke if it hasn't been ran in a while. Then get the kicker to set up all the way up and give it a swift kick and it fires right up. But usually it fires first kick if it hasn't sat for a weeks
