Aussie Quad Racer
Contact Methods
    Gold Coast - Australia
Aussie Quad Racer's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. Banshees are still available in Australia http://www.yamaha-motor.com.au/products/atv/sports/10-banshee-350
  2. i have not recieved a response from you?
  3. yes i have paypal, shipping address is 16 Robert Street Mudgeeraba QLD 4213 Australia If you could add the shipping price then i will pay
  4. if your willing to send to australia then you have a sale
  5. have you sold the cylinders yet?
  6. im after the 2-1 carb manifold that bolts to the cylinders, i dont need the carb or airbox adaptor. thou if you have complete setup i may be interested
  7. you do not need to upgrade stator if you going hid, they only draw 35w each, you will however need to alter the wiring and run a dc regulator
  8. it will work but may notice the light flickering
  9. bing carb is a simple carb with high and low speed adjustments only, very simple no good for banshee
  10. your slides are sticking open due to the moisture, it is common on banshee carbs, solutions are different carbs, heavier springs in carb or you can try polishing the inside of the carb where the slide runs. This is why yamaha has tors, they knew all along this would happen, road bikes using same carbies in late seventies suffered from it in the rain
  11. anyone have a stator assembly includes stator, plate and pickup they are willing to ship to australia at my expence of course
  12. are you willing to sent to australia? if so im willing to buy front end pending price of freight
  13. i beg to differ, i can alter the exhaust port timing on that motor which will reduce static compression but will result in higher stress on the motor in the top end. therefore requiring higher grade fuel. Fuel should be determined on numerous factors
  14. There is no reason why it would run hot by running straight water, but there is 3 reasons why we run coolant in the system. 1. to increase boiling point. 2. to reduce corosion 3. to reduce freezing points I do not recommend running straight water in any engine only due to the increase in corrosion that will occur
  15. depends on furthur plans for the bike and your type of riding, i suggest and prefer the single carb setup though
