Klotz
Everything posted by Klotz
  1. my buddy called me over to look at his banshee he said the kick starter was jamed...we took the side case off and the gear for the kick strter was over pushed into the case...when you push down the kicker it slides through the gear it suspose to grab and then it turns after it slides through .... ne one know whats wrong?? thanks shane
  2. yeah look out for cdw and klotz and watch out for those stock ex's they always seem to get you
  3. im goging to have to go with cdw on the one JBOMBR....i just dont know id you ready to take the next step and have nos...ive saw you ride before and you might want to work on your skills before you run with the big boys and put in nos
  4. i have it on my 400ex....and it is well worth the money.,..go with s wet system and i use it for flat track
  5. what differences does a stock banshee carbs to a 33 pwk or any 33 make....is it worth the money to go with the 33 and what are all the differences.. thanks shane
  6. do you have a teather switch casue if you do that messed up my spark..it sparked every tenth kick or so....so that could be it... shane
  7. Klotz
    tires
    any one else
  8. Klotz
    tires
    Right now i have 18" holeshots...i love them and they are the best tire i have ever had.....the problem is in the beads as many as you may know.......they dont seal worth a crap.....especially when your running 3 psi......so the question is i need to a good traction tire that will seal good......i run on mostly hard pact and i race motocross......somtimes go in the sand/gravel pits but mostly hard pact and motocross....also any ideas for the front tire......are there any out there that are just like the mx holeshot front??? for rear tires i was thinking about the kenda knarly! thanks shane
  9. 33 pwk...just installed some on a friends banshee and i couldnt believe it the difference that it made....but ive never rode one with 34 or 35 mm
  10. i also for got to say that i have 20cc domes if that makes a difference
  11. ok thanks guys...so can i run the gold gas at the gas station..the highest octane they sell at the pumps..and also DLNOSS im sorry i didnt buy a noss head...i really wanted to but my mom wasnt cool with the whole ordering with the credit card...sorry man!! \thanks shane
  12. I just installed my cool head last night....my banshee was sitting at 120 for compression and after i installled the cool head with 20cc domes it is now at 147 150 for compression....the problem is i just have stock pistons in there...can they handle this kind of compresion?? thanks for your help shane
  13. man your crazy....they prolly dont go flat cause you had so much air in them....but yeah 4-5 in the back...ive even ran 3 psi before and it was a bit low but works good
  14. for about a month!! you got to get hi temp
  15. ive been running 280s now for about 3 years and no problems..everyone says oh its gunna plow up and my plugs dont have ne white on them....and i race to with 280s its fine! shane
  16. yamaha makes a bumber that looks like the older style dg and this new one i have,,i cant explain it ill try to get a picture!!
  17. i did that i just bought a gauge from canadian tire and cut my rad hose in half and put it in there....sattered a copper pipe on.....then put it back on with hose clamps and it actaually works awesome ..the only problem is that it takes the temperature of the anti-freeze not the head it self! thanks shane!!
  18. i bent the one on my old ex before i had a shee and once you bend somethhing its not the same ne more..i say try it and see but moybe your better off getting a new one.,...unless your tight on money..but maybve try to bend it back then see how it holds up and go from there thanks shane
  19. i just got my new t5...i took them off to get ceramic dipped and they have a problem fitting where the front of the header meets the cylinder head......they dont go on flush..so they are croocked...ne sugestions thanks shane
  20. Pro circuits ahve no bottom end what so ever
  21. hey thanks guys i needed to know that too..my rear fenders have so many stress marks.... thanks
  22. i have no clue..could be fouled spark plugs..but i dont know alot about 2-srokes only 4..try postin in some other sections if you dont get any other replies
  23. i use bel ray exl
  24. i had my back rims painted balck..and at first they looked so awesome then after about 2 weeks thaey chipped from rock..common this is a banshee...wheel spin king..ne ways and then just little stuff like changing tires really made the paint chip bad and it looked terribel after a while....ne wasy just a heads up...maybe you want to look into powder coating thanks shane
  25. i used to own a 400 ex....my brother still does we just put a 440 in it and a hot cams.....its well worth the money..thats all you need trust me thanks shane
