ohSIXshee Posted October 24, 2014 Report Posted October 24, 2014 Im in the process of doing a dc conversion to run leds. I also want to relocate the cdi, battery and rectifier. Would this be ok or will it not run right with the different components this close together? Quote
ohSIXshee Posted October 25, 2014 Author Report Posted October 25, 2014 (edited) Also have a question about the ground i have racetech dc stator has 2 wires going to rectifier. Now does ground the battery to the frame? Edited October 25, 2014 by ohSIXshee Quote
trickedcarbine Posted October 26, 2014 Report Posted October 26, 2014 Keep the coil away from the CDI Quote
locogato11283 Posted October 26, 2014 Report Posted October 26, 2014 My coil and CDI on both my bikes are about 4" apart. It's not going to hurt anything. Quote
trickedcarbine Posted October 26, 2014 Report Posted October 26, 2014 Few inches is cool. But when guys try to stack it all together it can give it a stutter at wot. Quote
ohSIXshee Posted October 26, 2014 Author Report Posted October 26, 2014 Coil is in stock location. So cdi should be good next to the left hand head light? Quote
hoppedupandcutdown Posted October 29, 2014 Report Posted October 29, 2014 Don't know how far you are along, but this is a sweet set-up... http://bansheehq.com/forums/index.php?showtopic=179049&hl= Quote
ohSIXshee Posted October 31, 2014 Author Report Posted October 31, 2014 (edited) This is what i ended up doing. Probably over kill but its all hidden Edited October 31, 2014 by ohSIXshee Quote
ohSIXshee Posted November 4, 2014 Author Report Posted November 4, 2014 I cut off the stock mounts and mounted the flood lights. Quote
87sheerips Posted November 14, 2014 Report Posted November 14, 2014 I offer this bracket that takes care of battery, CDI and volt rectifier. Works Great Quote
ohSIXshee Posted November 16, 2014 Author Report Posted November 16, 2014 I offer this bracket that takes care of battery, CDI and volt rectifier. Works Great I follow you on instagram, i wanted something lower profile and didnt want to cut the brake line mounts. Although that probably doesnt matter so i just made my own. Quote
