10milmike Posted September 29, 2014 Report Posted September 29, 2014 Wicked is one of the best in the business.Roger been cutting override for over 20 years. Quote
RadarRacing Posted September 29, 2014 Report Posted September 29, 2014 IMO if you balance the tension properly on the duneables where the sliders will freewheel properly you can get away with much more backloading without having fork wear or bending/breakage. I did some writeups but was too lazy to do it on here. It helps a bunch. Quote
trickedcarbine Posted September 29, 2014 Report Posted September 29, 2014 Those write ups were on E2S right? Quote
possum Posted September 29, 2014 Report Posted September 29, 2014 I read your writeup radar, and I can vouch for it. I set my springs up properly and dune my bike all over and havent had ANY fork wear over 2 dune seasons. Quote
RadarRacing Posted September 29, 2014 Report Posted September 29, 2014 Here is the link. It is very simple to do , costs nothing but a few minutes when you have the trans sitting in the case half. The key to the assembly is being able to turn the transmission backwards in every gear without binding. If you dont do it , then you basically dont have a duneable transmission. http://sandslingers.com/index.php?/topic/499-duneable-override-spring-explanation-and-adjustment/ Quote
trickedcarbine Posted September 29, 2014 Report Posted September 29, 2014 I just don't get how there are all these low traffic sites that pop up and attract the same crowd, go stale, then ultimately shut down. Why go through the trouble any more? Quote
m671054 Posted September 29, 2014 Report Posted September 29, 2014 What tire/motor you plan on running? Weight of bike and rider would help. I could see needing first with a big tire moderate power setup but i dont think it would be able to pull on the top of the hill. Quote
registered user Posted September 30, 2014 Author Report Posted September 30, 2014 ive already started collecting some small stuff but first big thing on the list is a decent chassis setup. probly just go with a lonestar and jj&a axle etc etc. regarding the engine ill likely end up with a 10mil cub down the road but for now i think ill try some triple port stockers and see what can be accomplished with them. not sure the total weight of this combo. im about 200. not looking to break any records just want to have fun riding Quote
registered user Posted September 30, 2014 Author Report Posted September 30, 2014 Wicked is one of the best in the business.Roger been cutting override for over 20 years. is there any website for this guy ?? Quote
trickedcarbine Posted September 30, 2014 Report Posted September 30, 2014 It's been down for two years and his Facebook is fucking lacking. A premium example of why Facebook listing is nonsense. But roger is very easy to get in touch with and will always give you his undevided attention. Quote
10milmike Posted September 30, 2014 Report Posted September 30, 2014 1-714-530-2215 is his shop Phone number. His Name is Roger Arreola look him up on FB. Roger has been setting world records in asphalt here and in PR for over 20 years. He is not a site sponsor because he just does not want to be. I do believe he was one years ago. Call him you will see how much knowledge he has. Quote
registered user Posted September 30, 2014 Author Report Posted September 30, 2014 ill give him a call and see what he has to say Quote
RadarRacing Posted September 30, 2014 Report Posted September 30, 2014 Mine is a wcr but he had horrible reviews lately. Id use someone else. Quote
RagunCajun Posted September 30, 2014 Report Posted September 30, 2014 I ran a n-down 1-5 duneable(no 6th) for 3+ years from some guy's friend from here. I set my bike up geared to launch in 1st with pro wedge 2's. It took a lot of gearing and tires pressure adjustments to get it where i want it but it was worth it. Nearly all the locals used to launch in 2nd but i used 1st since my engine didnt have enough power usually to break the tires loose in 2nd and id bog. Also my bike made maybe only 60-65. It had trouble pulling 5th efficiently. Youll have to play with gearing and see what you like. Everyone is different. I feel the trans i have(since removed for a pro mod) gave me more tune ability since i had 5 gears to play with instead of 4. You can always sell it and get some money back. And lastly, dont cheap out. You can go broke trying to save a little money. Quote
Deadbeat Posted October 1, 2014 Report Posted October 1, 2014 I ran a n-down 1-5 duneable(no 6th) for 3+ years from some guy's friend from here. I set my bike up geared to launch in 1st with pro wedge 2's. It took a lot of gearing and tires pressure adjustments to get it where i want it but it was worth it. Nearly all the locals used to launch in 2nd but i used 1st since my engine didnt have enough power usually to break the tires loose in 2nd and id bog. Also my bike made maybe only 60-65. It had trouble pulling 5th efficiently. Youll have to play with gearing and see what you like. Everyone is different. I feel the trans i have(since removed for a pro mod) gave me more tune ability since i had 5 gears to play with instead of 4. You can always sell it and get some money back. And lastly, dont cheap out. You can go broke trying to save a little money. what happened to the 10mm supercub you got built...did it pull your lil cajun arms off or something Quote
