Kmaxwell12 Posted August 10, 2014 Report Posted August 10, 2014 Ok guys another newbie question lol. My banshee came with a amp link setup that but the dust so I ordered one roller but didn't know there are 2 plus a a arms slider till now. So how do I install them because I can't figure it out and I'm getting nothing with search or google. Any one got pics of how there's is set up? I know certain swing arm sliders you have to remove it to install the new one. Thanks guys again sorry for the new question. I'll make a how to for it with plenty of pics. Quote
special06shee Posted August 10, 2014 Report Posted August 10, 2014 I honestly can not make sense of this. Are you asking about chain sliders, rollers, or guides? Quote
Kmaxwell12 Posted August 10, 2014 Author Report Posted August 10, 2014 Ok haha its not the best to use a phone to post topics. The amp link that came on my shee bit the dust and I'm trying to find out how to install the 2 chain rollers that are suppose to be on the frame. I'm not sure where on the frame they go and needing pics or a diagram. Sorry for the jacked up first post my phone auto corrected stuff that didn't need it. Quote
Kmaxwell12 Posted August 10, 2014 Author Report Posted August 10, 2014 I have 1 roller that I believe is the bottom one. But I'm going to just buy a full kit with both rollers, swing arm slider, and guide from upp racing Quote
Kmaxwell12 Posted August 10, 2014 Author Report Posted August 10, 2014 Thank you hoppedup. That's exactly what I needed. Quote
Starwriter Posted August 10, 2014 Report Posted August 10, 2014 Also worth mentioning. See that white plastic roller, just below the big red circle? Since you have an Amp link, someone may or may not have removed that roller. Your aftermarket chain slide goes there. Some chain slides do not require removing the swingarm to install. However, if it is the stock swingarm, there is a pressed on steel sleeve on the swingarm that must be removed. You could grind away the roller and sleeve without removing the swingarm, but it would be better to just remove the swingarm, inspect the swingarm bearings, remove the steel sleeve, install the chain slide, and grease the bearings and the swingarm bolt. Hopefully the swingarm bolt isn't already rusted in. In case you haven't figured it out, the lower roller goes below the chain and the upper roller goes above the chain. Quote
Kmaxwell12 Posted August 11, 2014 Author Report Posted August 11, 2014 so ive heard a lot of good reviews on upp racing but is there any other brands that sell a complete kit for a banshee that is worth looking into? Quote
trickedcarbine Posted August 11, 2014 Report Posted August 11, 2014 No < just an opinion though. Quote
