jriffe23 Posted August 8, 2014 Report Posted August 8, 2014 Only weak pussy here is you. Stop being a coward and step up to the plate. Hmm, looks like no one likes you. Maybe you're the fucking moron. Sit here and tell me im the moron when the guys posts a thread on how to mod his banshee without spending any money and without upgrading. Not possible. P.S. nice voice you gay fucker. Quote
jriffe23 Posted August 8, 2014 Report Posted August 8, 2014 Only weak pussy here is you. Stop being a coward and step up to the plate. any memory of this forum zilla? http://bansheehq.com/forums/index.php?showtopic=175607 Oh yeah, where your ass got owned on tech by tfaith. Just saying buddy. Have a nice day. Quote
Glenyboy Posted August 8, 2014 Report Posted August 8, 2014 The new alba +2 a arms are cheap, they may still be able to hook you up with a good deal. Just say your a hq member or find the post on here. 1 Quote
sprinklerman Posted August 8, 2014 Report Posted August 8, 2014 DB, please quote the reply zilla made that you have a problem with so we can figure this out....would a shirtless picture do? Quote
Nash Jesso Posted August 8, 2014 Author Report Posted August 8, 2014 Need some help on what to do here,i changed my clutch cable because the other one was getting bad.i have about an 1/8" of free play at the lever,the clutch disengages a little but not as much as it should.when shifting into 1st the bike lurches forward but doesn't stall. Guy i got it from replaced the old clutch about a month ago,trans oil definitely needs a change.would new oil help or will i have to adjust the clutch at the pressure plate? Quote
jriffe23 Posted August 8, 2014 Report Posted August 8, 2014 Adjust the perch? or take the case cover off and adjust the actuator arm Quote
jriffe23 Posted August 8, 2014 Report Posted August 8, 2014 Why is this in the XC/ Hare Scramble forum??? Quote
Nash Jesso Posted August 8, 2014 Author Report Posted August 8, 2014 Didnt know if starting a new thread would be the thing to do,plus it was most likely already asked many times Quote
jriffe23 Posted August 9, 2014 Report Posted August 9, 2014 Your first post should have been in the suspension section anyways. Still doesnt make sense, but did you adjust that perch or try inspecting the actuator? Quote
jriffe23 Posted August 9, 2014 Report Posted August 9, 2014 This forum will help you with the actuator arm, just scroll down until he is showing how to adjust it and line it up. Cheers mate http://bansheehq.com/forums/index.php?showtopic=140912 Quote
Nash Jesso Posted August 9, 2014 Author Report Posted August 9, 2014 Thanks! Still getting used to how things work here,only other forum ive been on is pinkbike.com and things are done alot different. Quote
Deadbeat Posted August 9, 2014 Report Posted August 9, 2014 search engine is kinda fucky, use google type what you want to look for and add "bansheehq" 1 Quote
Nash Jesso Posted August 9, 2014 Author Report Posted August 9, 2014 Thanks,ill do that next time Quote
trickedcarbine Posted August 26, 2014 Report Posted August 26, 2014 You really are a moron. I will take it you are just a scared bitch and won't do a thing.I love this move! Classic. Simply put neither side likes on another. Therefore it becomes a bitch fest. Usually/statistically it's the weaker of the two to escelate the situation with extreme talk like ^. That way when your face for some unfortunate reason seems to not get hit, you can waltz around and blab about how you made that bitch scared. Ultimately karma will catch you. Quite literally it has already in my opinion zilla. When there's 30 people in a room and they all have argued with you, that's an issue on your end. Just an FYI. Quote
TIM LUTZ Posted August 27, 2014 Report Posted August 27, 2014 How about a steel clutch basket. LOL Quote
