Nash Jesso
Contact Methods
  • MSN
    https://www.facebook.com/nash.jesso
  • ICQ
    m
Nash Jesso's Achievements
  1. So its that time of the year where I look over the bike and pick out every problem I can find,minor or major and take the right action and replace what needs to be replaced. So I got my clutch cover bolts off,can anybody tell me the specs for the bolts? I found out my waterpump seal is gone(found coolant in my Trans) and I've finally found the damn air leak.it was my base gasket.so im getting all new gaskets and seals along with pistons.as for the water pump,is the bearing mandatory to replace even if it's not damaged? Hopefully I can get everything done before we get to much snow,few inches is fun to rip around in lol
  2. Yeah im replacing them with a hex head or Allen.
  3. Anyone have any idea how to get them out? The heads where the Phillips bit goes is rounded from the previous owner.im putting in a new clutch and gasket but I can't get the god damn cover off.. All help will be greatly appreciated!
  4. Yeah thats the plan,new top end,crank seals and all gaskets will be changed regardless of the condition the current ones are in.
  5. Soo i took the shee out for a rip yesterday and decided id ride one of the more aggressive tight muddy trails,it was fun,but a slight pain in the ass. Experienced the flaws of the front suspension,had enough low end and mid range to not give me trouble,i was beat after the ride. Now i realize that the biggest weak point is the front Suspension by far.
  6. Hasnt given bad readings for our sleds,its not a 10$ one so ill say im pretty sure its reading right. Did a leak down,found none.ill check to see if my pilot jet is dirty again but it only idles high for about 30 seconds if i dont choke it. When its warm it idles fine.
  7. Yeah found out not using choke on start up caused the rev problem. Did 3 tests per cylinder and all 3 peaked at 100psi.even though i havent lost and performance or and noticeable amount of power loss will it be safe to ride without any worries?
  8. What i thought,no loss in power and has alot of get up and go. Might ride it with caution till the end of the season and rebuild this winter
  9. I held throttle wide open,kicked till it peaked.tester read 100
  10. My shee starts first kick but idles high,it calms down as soon as i pull the choke and idles fine,anybody know why? I also checked my plugs and they are black,so im guessing im on the rich side,my jetting is stock(the bike is bone stock) and gas is mixed 40:1,is this a problem? While I had the plugs out i checked compression,both cylinders peaked at 100 psi at about 10 kicks. And is there a difference between a br9es plug and a br8es plug,when i got my shee it had the br9 and that is currently still in there,would switching to a br8es be better? Thank to anyone who can help
  11. I was thinking lsr arms, works shocks,fmfs or pro circuits,eventually 4 mill crank,itp hole shots or sti tech 4 xcs all around,billit impeller,toomey air filter, and i guess porting( where can i get that done?)
  12. Most trails here are wide open,lots of straights and wide turns,some tight stuff but all of the trails have been redone so they can be used by cars. First ride i went on i rarely used 2nd and 3rd gear.
  13. Yeah my step dad's cousin has a banshee with fmfs and its alot snappier than mine which is stock.im thinking cpi pipes or t5s and a toomey 2 into 1 filter along with a billit impeller.
  14. Dont plan on running it in drags,just for racing around in the trails and a bit of sand. Probably not going as far as porting,mostly blot ons for mods.
  15. Ill try not to.
