B.b.p builders Posted July 7, 2014 Author Report Posted July 7, 2014 What oil and at what ratio are you running? Those plugs look really lean... The heat going down the treads like that is not goodSo it is lean. Shit'Mix is 24:1 with maxima 927 Guess I will adjust the needle some more. Cause I have tried adjusting powerjet both ways already with no luck! Quote
J-Madd Posted July 7, 2014 Report Posted July 7, 2014 Hmmm. My strap and/or porcelain would be gone if mine looked like that after 2 passes. Any metal flaking on the plugs? Erosion of the strap? Never seen plugs like that after 2 passes. Quote
B.b.p builders Posted July 7, 2014 Author Report Posted July 7, 2014 Really?? Then wtf? Nothing of what you ask. Plugs look just like that. Went and bought them brand new, put them in and ran it, back to back, took them out and took a picture. Motor is boggy down low a bit, but pulls pretty hard, but it was running better then it it now. Quote
CottonBranchRacing Posted July 7, 2014 Report Posted July 7, 2014 Shits gettin hot yo.. CottonBranchRacing Quote
camatv Posted July 7, 2014 Report Posted July 7, 2014 ran back to back.. plugs have 2 passes back to back on them. motors continue to create heat every run. if they dont cool down to idleing temps in the pipe and in the moor you will have readings that are a lil off not necessairily a bad thing you would want to tune the motor to overall have a good strap, base reading and NOT a one pass good reading. since you ride the bike and its not a track one pass bike that makes a difference.. get new plugs. change mix ratio to 32-1 gap plugs at .18 tho adjust needle to idle, have clean just of idle performance. bottom pj's turn them 3 turns out. ride bike. make one full throttle pass. stop yank plugs look at the burn ring. if plugs are clean and show no heat at all OR if bike blubbers and wont run clean. raise needle 1/4 turn, adjust pj's in half turn. reinstall run again. you want to watch the burn around the base of the plugs. the one on the left looks fine the one on the right looks grey, and the burn ring from what i can tell is right at the strap. measure your needles length and see if they are the same length left to right. might also check to see if your pj's are drilled the same size left to right if they are you should probably do a quick leak down test OR run the right side 1/2 turn more on the pj. basically what i look at IF i actually pull the plugs out is the closer to the strap the burn gets the hotter it is running. timing i just adjust untill the top end drops off and back it down a tad from there. anymore i dont even look at the plugs i know from riding what the motor is going to want. if i think there is a problem i will check the plugs if you have the needle set about right ( not to rich not to lean) and first pass with pj's all the way open it blubbers from to rich pj, just turn them down 1/4 turn till it cleans up. thats your max rich setting to run.. easy.. 1 Quote
SOUTHTHIRTY Posted July 7, 2014 Report Posted July 7, 2014 Dump those s lectrons. ..or have proset them up ...few more passes like that...you, ll be looking for a new top end Quote
badassbanshee479 Posted July 7, 2014 Report Posted July 7, 2014 Open power jets wide open make a pass check plugs... Keep leaning out pj a 1/4 turn ea pass till the burn ring is at 3 and 9 o clock. You deff don't want heat to show on the plug after one pass Quote
B.b.p builders Posted July 7, 2014 Author Report Posted July 7, 2014 U guys might be surprised to know that the power jets were both backed all the way out and then only turned 1.5 turns in. My fuel mix was at 20:1. I'm not sure if most of you are seeing the picture well. I don't believe it's BURN you are seeing. I did one more pass after this picture, before that pass I turned my power jets IN (leaner) one full turn each? Bike performed better, also started to clean up the plug, it got spotty, as in some dark spot like pictured, with some lighter spots kinda like it was drying up, if you could imagine that pictured, I should of just took a pic, but didn't. I will mix at 36:1 and do a pass I bet that even cleans it up, I'm sure most of you going o. About it being lean and so surprised it hasn't blown are thing no way, but then why has no blown up yet? Why is there no piston residue, I'm not talking I k&t 2 passes, 2 passes in that pic!! Did probably ten through out the day!fucking with it every pass, but with basically the same looking plug. Cause it must be ritch. Anyway I will post back the results so others who might need one day have it. No matter what the results are I will post them. Even a blown motor. Quote
trickedcarbine Posted July 7, 2014 Report Posted July 7, 2014 (edited) < loves carnage Hope you get it sorted out. Edited July 7, 2014 by trickedcarbine Quote
special06shee Posted July 7, 2014 Report Posted July 7, 2014 Why are you changing oil mix? If i were you if stay at 20:1. Quote
badassbanshee479 Posted July 7, 2014 Report Posted July 7, 2014 Never had Alky plugs come out of any of my bikes looking that shitty running klotz super techniplate at 24:1 even when they where so fat they wouldn't clean out... Quote
B.b.p builders Posted July 7, 2014 Author Report Posted July 7, 2014 In no way am I trying claim I know what's goin here but when you guys saying that if thier plugs looked like that the motor would be toast. It makes a guy wonder? I have quite a bit of time on this motor. Run time. Like common after 10grand spent on this bike, that's the last thing I want. I'm home from work and at it again with this thing. Quote
B.b.p builders Posted July 7, 2014 Author Report Posted July 7, 2014 Not to mention who knows who is commenting and if they even read the thread from the start? I know when camatv comments, I believe and read what he says. But I looked at many if his old post and trust he knows what he says. Many of you may also, but many of you might also be as clueless as I or worse. I'm a guy who can tear this motor to all it's pieces and put it back together, and it still run. Just so everyone knows I'm not a virgin here, just new to alcohol. If this was a dam gas motor I would of had it running the day I put it together!! Quote
