10 cub alky failure
30years
Looks like detonation damage to me. It also looks like the rings are melted into the piston and then maybe part of the ring is either gone which scarred the piston up or metal of some kind has hit the piston. Either ring piece or crank bearing. There is detonation damage there too from high temps but detonation marks are mostly on the squishband area of dome and piston. You have that plus what looks like ring hitting piston. Detonation causes temps to skyrocket very quickly which probably ended up doing the frint side of the piston where the ring is melted into it.
check the edges of the outsides of the base gasket..    would have been good to do a leak test before tear down BUT  it needs to completely come apart.  check crank or replace if needed.
Looks like you need to check crank really well to me!!
