cciao Posted July 6, 2013 Report Posted July 6, 2013 Between CPIs , shearer, r2s, snipers? What pipe holds the most low end to mid? (with a 4 mil dune port) . Quote
Deadbeat Posted July 6, 2013 Report Posted July 6, 2013 http://bansheehq.com/forums/index.php?showtopic=168403 Quote
camatv Posted July 7, 2013 Report Posted July 7, 2013 depends on porting.. id lean this way BUT i have never had or messed with r-2's.. sniper cpi shear. all will be very close in LOW TO MID performance. Quote
special06shee Posted July 7, 2013 Report Posted July 7, 2013 depends on porting.. id lean this way BUT i have never had or messed with r-2's.. sniper cpi shear. all will be very close in LOW TO MID performance. Did you try a set of snipers?? Quote
sprinklerman Posted July 7, 2013 Report Posted July 7, 2013 Between CPIs , shearer, r2s, snipers? What pipe holds the most low end to mid? (with a 4 mil dune port) . I know you didnt mention it,but have you considered Pro Circuits ? They do good in the low/mid department. Quote
cciao Posted July 7, 2013 Author Report Posted July 7, 2013 Is there that much of a difference between the CPIs , shearers. Or is it personal preference , ford vs. Chevy . Quote
trickedcarbine Posted July 7, 2013 Report Posted July 7, 2013 I believe the OP is looking to determine which of the common bigger inframe "drag" pipes will still hold the most bottom. Not which pipe out of the entire market. If that is the case, I'd say the CPI's. Maybe a set of Rockets. Good luck finding a used set of either. There are a lot of CPI owners out there and almost none of them are selling their pipes. That should tell you something about the quality of their product. Quote
cciao Posted July 7, 2013 Author Report Posted July 7, 2013 Thank you . Exactly what I was looking for, not wanting a used set. Where's the best place to order a new set? Quote
sheerider11 Posted July 7, 2013 Report Posted July 7, 2013 I believe the OP is looking to determine which of the common bigger inframe "drag" pipes will still hold the most bottom. Not which pipe out of the entire market. If that is the case, I'd say the CPI's. Maybe a set of Rockets. Good luck finding a used set of either. There are a lot of CPI owners out there and almost none of them are selling their pipes. That should tell you something about the quality of their product.Very true, it took me about 6 months to find my CPI. Quote
trickedcarbine Posted July 8, 2013 Report Posted July 8, 2013 Order them from CPI direct or call the site sponsors and see who has the best deal currently. Quote
sheerider11 Posted July 8, 2013 Report Posted July 8, 2013 Used. No one wants to part ways with them once they have them. Quote
n2otoofast4u Posted July 8, 2013 Report Posted July 8, 2013 depends on porting.. id lean this way BUT i have never had or messed with r-2's.. sniper cpi shear. all will be very close in LOW TO MID performance. You been drinking bath water again? Quote
possum Posted July 8, 2013 Report Posted July 8, 2013 Thank you . Exactly what I was looking for, not wanting a used set. Where's the best place to order a new set? I thought I was told that Redline Racing sells CPI? Maybe someone can confirm. Quote
locogato11283 Posted July 8, 2013 Report Posted July 8, 2013 I thought I was told that Redline Racing sells CPI? Maybe someone can confirm. Yea, Cameron deals with them quite a bit. Give him a call. Quote
