depends on porting..
id lean this way BUT i have never had or messed with r-2's..
sniper
cpi
shear.
all will be very close in LOW TO MID performance.
sniper
cpi
shear.
Did you try a set of snipers??
Between CPIs , shearer, r2s, snipers? What pipe holds the most low end to mid? (with a 4 mil dune port) .
I know you didnt mention it,but have you considered Pro Circuits ? They do good in the low/mid department.
I believe the OP is looking to determine which of the common bigger inframe "drag" pipes will still hold the most bottom. Not which pipe out of the entire market. If that is the case, I'd say the CPI's. Maybe a set of Rockets. Good luck finding a used set of either. There are a lot of CPI owners out there and almost none of them are selling their pipes. That should tell you something about the quality of their product.
Very true, it took me about 6 months to find my CPI.
sniper
cpi
shear.
You been drinking bath water again?
Thank you . Exactly what I was looking for, not wanting a used set. Where's the best place to order a new set?
I thought I was told that Redline Racing sells CPI? Maybe someone can confirm.
