I'm going to add more rubber engine dampers see if that's helps the chain issue and make sure there is no binding. Do u think adding a roller tensioner would help since I'm running a +12
Does it ever sound like your trans is popping? Which is many times your chain popping on the front sprocket as it is kinda trying to climb over and pop off the sprocket. It can do it while riding slow with no load and that would be swingarm alignment. If it does it when you have a load and are accelerating that can be motor tweaking. You can add extra stock washers like the rear motor mount has and add then to the front. I had to get Stellars adjustable bottom motor mount struts. They fixed my problems. $55 well spent.
If you dont have the extra half washers in the front get them and put them in the front mounts. They come stock only in the rear bolt.
Actually from the factory they are on the left of the front bolt and on the right of the rear bolt.
