#1JUANstunna Posted February 28, 2013 Report Posted February 28, 2013 Fuck wire nuts just twist together and halfass tape that shit. Its been workin for Yamaha for years. Quote
trickedcarbine Posted February 28, 2013 Report Posted February 28, 2013 Pretty straight forward. Quote
Scrubtherubber Posted February 28, 2013 Report Posted February 28, 2013 good write up heat shrink butt connectors for me a little pricey but worth it 1 Quote
Nightmare Posted February 28, 2013 Report Posted February 28, 2013 Clean and simple. Sent from my SGH-T679 using Tapatalk 2 Quote
locogato11283 Posted February 28, 2013 Report Posted February 28, 2013 what is that 4 gauge? 6 or 8. I can't remember what I bought. - HMFIC Quote
hoppedupandcutdown Posted February 28, 2013 Report Posted February 28, 2013 Let me start this by saying that I'm a hugeadvocate for proper grounds. I've fixed many an odd problem on cars, boats andRV's because of bad grounds. My Dad was a GM service rep ,and in 1968 found outwhy the new body style GTO's with automatic floor shifts were all seizing theshifter cables. No ground strap to the body,and ground was trying to run throughthe shift cable. I too was wondering about the Banshee electrical system andproper grounding since I just installed my motor in a freshly painted frame. Idid "bare metal" all the mounting points of all mounts. But after buyiing andusing 4 new damper shims, I couldn't see how the motor would possibly touch theframe- metal to metal. Not that the Yamaha engineers purposely meant to isolatethe two, but they certainly didn't do the opposite either. Anyway, tonight Iremoved my chain,clutch cable,lower exhaust springs, exhaust brackets, anddisconnected my wiring, Ohm meter proved it- totally isolated. I can't believethese don't come with a ground strap from the factory. Quote
JasonsBanshee Posted January 31, 2014 Report Posted January 31, 2014 Awesome write up. I tore my bike down last night to paint the frame. Correct me if I'm wrong, but the only component in the stock wiring that actually grounds to the frame is the voltage regulator? Everything else had two or more wires going to it which indicates to me that a hot and a common/ground is being supplied to the component through the wiring harness. I am going to put a ground strap between my motor and frame, but it would seem that running a ground wire from the engine to the voltage regulator would be just as good? I've built hot rods and other cars/trucks from the ground up and definitely know the headaches a ground issue will cause that can be fixed with a simple ground strap so I too would highly recommend one, but on a Banshee, unless I'm not understanding it right, the only thing grounded to the frame is the voltage regulator. Quote
J-Madd Posted January 31, 2014 Report Posted January 31, 2014 I've been saying that for years. It's already grounded in the harness. I've ran zero grounds, and even had the coil zip tied on, so it wasn't grounded either. Quote
camatv Posted January 31, 2014 Report Posted January 31, 2014 ummm.. the banshee motor is ruber mounted not sure if anyone brought that up.. the only OEM ground from the stator is from the main ground going to it from chassis ground ( wire on regulator mount) . that same ground feeds everything else. i have found multiple breaks in that ground or the connection is all rusted up from contamination on the backside of the stator.. the coil, ignition etc is all grounded through the cassis. Quote
JasonsBanshee Posted January 31, 2014 Report Posted January 31, 2014 ummm.. the banshee motor is ruber mounted not sure if anyone brought that up.. the only OEM ground from the stator is from the main ground going to it from chassis ground ( wire on regulator mount) . that same ground feeds everything else. i have found multiple breaks in that ground or the connection is all rusted up from contamination on the backside of the stator.. the coil, ignition etc is all grounded through the cassis. Isn't the coil (ignition is the same thing) grounded through the black wire? The coil has a black and an orange wire. The black is the ground. It would seem to me that the only place anything grounds to the chassis is in the rear on the voltage regulator. Looking at this diagram, I see three grounds. The voltage regulator and each spark plug. That being said, it would seem that you could just run a ground wire to the voltage regulator and not worry about rather your frame is grounded or not. Quote
camatv Posted February 1, 2014 Report Posted February 1, 2014 wow i just noticed that diagram dosent show any actual ground from the main harness to the regulator at all. i know there is one there and also the reg grounds through its casing. the coils casing ( mounting bolts) actually ground to the chassis. if there is any kinda bleed off the casing ground kinda takes care of it. according to yamaha as long as the threads on the bolts are kinda sorta into metal its good.. also the plugs ground into the motor and that would rely on the stator's ground to run... like a lot of things on these bikes the elecrical is retarded simple you can relly think way to much into it and forget the golden rule K>I>S>S> Keep It Simple Stupid.... i can test the integrity and pretty much any electrical failure right off the back of the bike with the 2 cdi plugs.. Quote
hoppedupandcutdown Posted February 2, 2014 Report Posted February 2, 2014 If you take a coil off the bike and check continuity from the mounting bar, it is isolated from the ground terminal. (both terminals for that matter). I've read on a XS650 forum (another Yamaha twin) that the reason to mount the coil to bare metal on the frame is actually only for heat dissipation. Any way, for whatever reason, I know my bike is over-kill on grounds. Quote
camatv Posted February 2, 2014 Report Posted February 2, 2014 in one of my advanced electrical diag classes we had talked about if a coil has the metal areas exposed in its mounting screws ( like the banhsee coil and a lot of gm tbi stuff, hei etc) tis a good idear to make sure that the mounts are a good ground to them. also HEI ignitions also have a ground strap to the case of the coil under the cap. this makes a path for any electrical "noise" ( if i rember) somewhere to go. its simple i jsut make sure the frame is clean under where ever the coil is mounted. if in the stock location or somewhere custom. no biggeee if anyone dosent understand why its done read about hei ignition coils. i recently had to replace the coil in my ole hotrod from some retard not installing the ground strap from a from a mount bolt to the center ground. it cooked the wiring inside the cap, even the new coil had a nice instruction paper on how important this casing ground strap was... just my suggestion. just like the suggestion to add a 4 ga ground wire from your case to the frame. after thinking about this more and more maybe the spark plugs could benefit from the added ground.. but in my experience more problems from crappyily installed stators, crappy powdercoating grounds, shitty wiring and disregard for proper grounding in general, motor painting etc are the problems most of us deal with. not the results from not having an added ground strap/.. Quote
