I have both, so i'll speak on this comment.
CamAtv's "Pro Mod" isnt the "same" as an over-ride,but it gets as close as i can imagine you getting without having to worry about backloading at all.
 You can either barely lift and pull up to the next gear,or you can slip the clutch a touch and click up.
My WCR  "Pro Mod " trans does that.....so I'm assuming they are about the same?  (But Cam just said his modded stocker will shift full throttle without lifting....so which is it?)
  • Replies 32
  • Created
  • Last Reply
Top Posters In This Topic
When he means not lifting, he means he has to use the clutch.
Correct me if I'm wrong. Other wise, it's an override.
I think he means you can just twitch and hit the clutch and it'll slide into the next gear, or back off just a hair and pop into the next gear. Pretty much wot shift
^^^  Yes, thats what  i meant.  I should have explained it better i guess.
With Camatvs "pro mod" you can do pretty much a WOT upshift by either a blip/slip of clutch whille keeping the throttle pinned (maybe the 1st 15% of lever pull)  OR you can lift the throttle about 15-20% and upshift,then fully pin it again. I think this is a great tranny for the guy that cant commit to an override for whatever reason.
 For a  drag bike,id do what  JAWS  :jesterlaugh:  ( guy right above me) said, get Redline to cut you an over-ride. Then you dont have to clutch or lift in the slightest.
I have a WCR promod (modified stock cut) and it is fucking titties! If I ride it just right I can get away with out any throttle lift or clutching. Not all Trannys are the same. Most guys think you just cut every other dog and that's it. Mine has a whole multitude of different tricks that I didn't even notice till I had it next to a bone stock stocker. I have heard many good things about cams trans mod and my next play/race tranny will be from him. Greg at WCR does good work, but his attitude and service are just poor now.
He just fucked over the guys from Cuervo Racing. They were supposed to have transmissions long before 4-Stroke Wars. Not only did they not make it in time, one of them broke the first trip out.
Not to get to far off topic, but now that you're in the raptor scene. Will there be a big thumper climber in your future?
No way.
