Got spark. Won't start!
Jraz
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
With good compression , fuel, air and spark is all that is needed to run.  If you you actually have spark the wiring is correct.  If it was a kill switch, key switch, or tors you wouldn't get spark.  It is a logical troubleshooting process.
SP
How crazy is this though. My on, off switch never worked before only the lights. Would run no matter where the switch was positioned
That's likely nothing more than a dirty set of contacts inside the housing.  The contacts for the run stop need to be open to run.  When they are closed it grounds the ignition signal and no more spark.  Intermittent spark is usually a mis adjusted pickup.
SP
Yep, got fuel. Lol. Gap set at .016. At this point I'm leaning toward a bad cdi. Problem started when my stator rattled loose and got damaged from the flywheel. So I replaced the stator, flywheel and ignition coil. Weird how easily the new flywheel comes off the crank. My woodruff key is worn some, but other than that., its sparks totally random.
