HolySheet
Everything posted by HolySheet
  1. Try charging the battery. And did you rotate the air in the tires?
  2. If it has a little stumble I would re check compression, and clean the air filter. Could also be a sticky reed.
  3. I didn't get a PM.
  4. http://cleveland.craigslist.org/mcy/3707302733.html I just sold my Banshee and now this dipshit is re selling it. What makes it better is he has no idea what he's talkin about.
  5. Ttt sorry all, been in Alaska for a few weeks. PMs replied. And no I'm not by Indiana, I would consider sending you the paddles first then you send the money.
  6. Funniest shit ever.
  7. I don't have "homeboys", I'm white.
  8. Who is foxrider?..
  9. Whoops. I mean they are 67.95 at the piston crown. But are 68mm.
  10. 135psi in each.
  11. Wiesco Pro Lites. 66.55mm.
  12. I am curious as to how much I can bore with it being at 68mm. I don't know how much life is left in them.
  13. I really want to try this on my boots.
  14. In all honesty my trail port stock cylinder runs great. I see no reason for a serval unless you have money to waste.
  15. Port the stockers, advance your timing and get some good reeds.
  16. Yes, stock stroke 68mm bore. Stock cylinders. 392cc
  17. Someone at a machine shop bored them to 68mm. Stockers can go to 68.25mm if I remember right.
  18. Stock cylinder 68mm bore.
  19. Yes. I wish it was smaller but it's not.
  20. Cut stock head, it's a 68mm bore with matching pistons, and it is trail ported. Without porting it would be a turd I think...
  21. It not worth it. Send your cylinders off to get ported and you will be happier. If you have the money then do both. I have a ported 392 and it rocks.
  22. Where are the pinch clamps on those intakes?...just asking for trouble without them.
