Hazzard Racing Customs Posted December 2, 2012 Report Posted December 2, 2012 Hey guys im building a 10mill i want to get some opinions on whether to put a serval top or a cub top i like to trail ride but also like messing around draging so im stumped any info or opinions would be greatly appreciated thanks HAZZARD Quote
vulvafan537240 Posted December 2, 2012 Report Posted December 2, 2012 call a builder. a serval can be ported to cub specs or anywhere in between to suit your riding style. Quote
SuperMex Posted December 2, 2012 Report Posted December 2, 2012 A cub can be ported to run just as hard across the whole rpm range as a serval if ported by the right person. It will pull much harder on top though. Quote
Hazzard Racing Customs Posted December 2, 2012 Author Report Posted December 2, 2012 SO YOU GUYS THINK A CUB PORTED TO THE RIGHT SPECS WILL DO EVERYTHING A SERVAL WILL DO BUT STILL HAVE THAT TOP Quote
Redline Racing Posted December 2, 2012 Report Posted December 2, 2012 If you wanna run pump gas I recommend a serval. If race gas is ok a cub is prob better. Quote
crazycracker520 Posted December 2, 2012 Report Posted December 2, 2012 If you wanna run pump gas I recommend a serval. If race gas is ok a cub is prob better. What? The cylinder has nothing to do with fuel used to run it!! Compression & Timing are the only things that affect the burn characteristics required to not detonate! crazycracker Quote
dirtydownunder Posted December 2, 2012 Report Posted December 2, 2012 dick heads. if youre running race gas you obviously want the most out of your motor, because you are probably racing. and i doubt youre going to be racing other servals on race gas. Quote
locogato11283 Posted December 2, 2012 Report Posted December 2, 2012 Redline racing, why is that?? What? The cylinder has nothing to do with fuel used to run it!! Compression & Timing are the only things that affect the burn characteristics required to not detonate! crazycracker Are you two fucking morons really going to question one of the top builders in the country? Do either of you know a fucking thing about building motors? Shit never ceases to amaze me. Quote
possum Posted December 2, 2012 Report Posted December 2, 2012 i just want to know what one of the top builders in the country recommends and why. Quote
special06shee Posted December 2, 2012 Report Posted December 2, 2012 Man, some people here should become builders! Seems they have it all figured out! All i know is, i would highly recommend listening to Cam! He is a super wizard with this shit! And yes, im swinging from his nuts! Quote
dajogejr Posted December 2, 2012 Report Posted December 2, 2012 Do either of you know a fucking thing about building motors? You really had to ask that? You slippin? Quote
possum Posted December 2, 2012 Report Posted December 2, 2012 Man, some people here should become builders! Seems they have it all figured out! All i know is, i would highly recommend listening to Cam! He is a super wizard with this shit! And yes, im swinging from his nuts! thats why i asked. he would know more then anyone else. im listening Quote
lms1977 Posted December 2, 2012 Report Posted December 2, 2012 Redline racing, why is that?? If you wanna run pump gas I recommend a serval. If race gas is ok a cub is prob better. What? The cylinder has nothing to do with fuel used to run it!! Compression & Timing are the only things that affect the burn characteristics required to not detonate! crazycracker when you run race fuel you can run alot more compression and timing which will make a cub easier to trail ride... I went from pump gas to race fuel with my 10mil serval and it was night and day difference in how it runs WAY more power everywhere Quote
trickedcarbine Posted December 2, 2012 Report Posted December 2, 2012 RetardedCracker520 "If you wanna run pump gas I recommend a serval. If race gas is ok a cub is prob better. What? The cylinder has nothing to do with fuel used to run it!! Compression & Timing are the only things that affect the burn characteristics required to not detonate! crazycracker" You are RE-FUCKING-TARDED! There are several reasons to make that determination based on the cylinder type. If you set up the cub properly it can make more power across the board, but it needs the compression and timing to do so as well as proper domes and porting. Which in the end would give you more then any serval would. I'm not the builder but that is only the brief break down of it and I'm just not sure you grasp where Cam was going with that, but you should definitely pump your brakes and investigate further in to what it is he means before you get gutted on here. Quote
