Billet Case Savers
erickson483
15 tooth is no problem. You might have to shave the case saver a little to accomodate it, but you won't have to remove much, if any material to fit a 15T sprocket. All the case savers I have seen go over the neutral switch cover.
I also suggest staying away from billet, go with plastic or a "soft" material. Tyler is correct, you want it to absorb the impact, not transfer the energy.
  • 3 weeks later...
Does anyone have any experience using billet case savers to help protect your case from chain whack?
I threw my chain, luckily had a case saver. It still cracked the case but it didn't crack all the way through, I was able to ride back to the truck. I think they're worth the 25 bucks.
