MorrisJL Posted January 20, 2011 Report Posted January 20, 2011 So its time for me to change my transmission oil...problem is I don't know what I should use. I've read arguments on various websites and forums but haven't really found anything on bansheeHQ about this subject. Should I use an automatic transmission fluid or light weight motor oil...? If I use the ATF, I understand I will need to change the fluid more often but read from multiple posts that it will extend the life of the clutch... a light weight motor oil will protect the transmission just the same but can cause the clutch to slip...? I'm sure the transmission as of right now has a lightweight motor oil and I can't say I've noted the clutch slip. What is everyone else using... any bad outcomes with either type of fluid use...? Quote
Wicked ATV Posted January 20, 2011 Report Posted January 20, 2011 So its time for me to change my transmission oil...problem is I don't know what I should use. I've read arguments on various websites and forums but haven't really found anything on bansheeHQ about this subject. Should I use an automatic transmission fluid or light weight motor oil...? If I use the ATF, I understand I will need to change the fluid more often but read from multiple posts that it will extend the life of the clutch... a light weight motor oil will protect the transmission just the same but can cause the clutch to slip...? I'm sure the transmission as of right now has a lightweight motor oil and I can't say I've noted the clutch slip. What is everyone else using... any bad outcomes with either type of fluid use...? We use this in ours and all customers bike. We got more info on the oil as well you can look at My link Hope you find the info Helpful 1 Quote
Coupelx Posted January 20, 2011 Report Posted January 20, 2011 atf here. do a search. this has been beaten to death several times over. Quote
So Cal Suspension Posted January 20, 2011 Report Posted January 20, 2011 This is what I use: I bought it for one simple reason. It's got the handy little spout on the top for easy filling Quote
gotta_goatsfast Posted January 20, 2011 Report Posted January 20, 2011 Why do people chose to run other types of oil in their trans when there is a specific TRANSMISSION OIL! Do you run white oil in your lawnmower? NO. Maybe we should all start running 10W-40 deisel oil in our automatic transmissions... See where I'm getting at? The ATF will not extend the life of your clutch. ATF breaks down quickly when overheated. It is tough stuff in an automatic transmission where the clutches and bands slip for a fraction of a second between gear shift and you have a fluid cooler to keep it under 220 degrees. Some people go more than 100K miles without changing it. BUT, feather your clutch to get back into the powerband or drag race a few times under full load launches and you'll soon realise your friction discs glazed over because the ATF is burned and broken down. Honda transmission oil (posted by MattSCESC) is what I use and find myself changing it in the spring and in the fall. Is it more expensive per volume than ATF? Yes, is it more expensive to change trans oil twice a year than ATF every other weekend? no... Quote
06specialedition Posted January 20, 2011 Report Posted January 20, 2011 I've always ran cheap ATF Type F with no issues. This summer I'm going to change to Klotz Flex drive though Quote
bansheesrtoys Posted January 20, 2011 Report Posted January 20, 2011 atf sinks too, and the smell just gets worst with time. i use golden spectro clucth saver. never had a prob in the last 6yrs. Quote
87sheerips Posted January 20, 2011 Report Posted January 20, 2011 ATF type F. Change it 2 times a year in my drag bike without issue... Prob change 3 times a year in my trail bike since the clutch sees more abuse without the lockup Quote
tundish2800 Posted January 21, 2011 Report Posted January 21, 2011 either atf type f or i run mobile 1 syn 10w30 Quote
Huey73 Posted January 22, 2011 Report Posted January 22, 2011 I've run 80w90 and have gone back to 10w30. In the colder temps the tranny takes to long to warm up and the clutch feel is better with the 10w30. jmo. Haven't tried ATF and likely won't. 10w30 is what is recommended in the clymers. Quote
shee4speed Posted January 22, 2011 Report Posted January 22, 2011 This is what I use: I bought it for one simple reason. It's got the handy little spout on the top for easy filling x2 Quote
bigborebanshee Posted January 22, 2011 Report Posted January 22, 2011 Klotz flex drive, Belray gear saver or Honda HP in 80-85 wt.Even after a whole season,the oil comes out as clean as it went in. The only drawback to the 80 wt oils is the clutch plates will stick a little bit when cold , even after it warms up neutral is always hard to find. I did not notice a problem until after I changed to an aftermarket clutch and omitted the clutch o-rings.they definitely helped seperate the plates when the clutch was engaged. Quote
BigRed350x Posted January 22, 2011 Report Posted January 22, 2011 ATF type F. Never had any issues with clutch wearing out or any of that. I change it every few rides. Quote
Meat Posted January 23, 2011 Report Posted January 23, 2011 Last year I switched over to Redline's Lightweight Shockproof tranny oil and I dig it. Its blue in color and sticks to everything. Their "lightweight" is a 75W oil. If you watch my YouTube video's you'll see the newest videos show me ripping down my 250R to replace the counterbalancer and you can see the Redline oil on the clutch parts. The quad was sitting for at least a month after I drained the oil and when I took the clutch side cover off, everything was still coated in blue oil. I run it in my RZ too. My RZ and 250R would both stall out when I ran other oils and didn't warm up the oil really good before I took off, but after switching over to Redline, I could see a difference in the warm up time. Let the quad sit for 7 days on a cold October day, fire it up, warm it up for a few minutes, work the clutch lever a little while warming it up, click it into gear, commence to ripping it up. Redline 'lightweight Shockproof' tranny oil, check it out sometime. Quote
