ok ive been trying to set the psi just right and i cant seem to find it, i know your only suppose to run a few psi but if you guy can give me a starting point that would be great
are you trying to get more traction or a smoother ride? I usually run my tires a little soft so they flex and roll a little bit in the corners and berms, if you air em up hard they like to spin and slide easier.
around 8ish.. ive ripped my beeds off of beadlocks with 4 from reving and droping it. the rim spun but the tire didnt on the ground and i tore the tire wall off the tread.. fun ride back.. but yah i run 8ish with or without beadee's front and back. i ride on streets, muddy trails, and rocks, fields, sand, ice, and snow..
I think this is to broad of a question.
You have to be more specific on what you are trying to accomplish here.
I believe it will vary with conditions, tire size, mods etcc
I have 21" razr in the front and run 6psi where we ride.
I run 22's in the rear and run from 1-4psi
The rear tires, even with 1psi they feel like 4.
Are you spinning to much, are you hooking to hard, what kind of terrain do your ride, what are the conditions usually like??
I think you need to find what you and your bike like and just roll with it...
the fron feel like they dig way too hard in corners even when im leaned back and those are puresports 21x7x10 i think off an older raptor 660, the rears are razr2s 22inch i dnt know the other dimension , and they dont hook well out of the corners
I run 4-6 in the rears (Kenda Klaw XC's), and the same up front (stock), since i switched to the the 450 front end. When i had the stock banshee front end, i ran them a little harder (more psi, fronts only) to compensate for the lack of suspension travel. I've tried different psi combos and like these the best for my current set up and body weight.
