jimbob Posted January 19, 2009 Report Posted January 19, 2009 does any one have a pic of what the finished product should look like or a"how too" anywhere. i've done a search but cant seem to find anything. cheers Quote
spurdy Posted January 20, 2009 Report Posted January 20, 2009 does any one have a pic of what the finished product should look like or a"how too" anywhere. i've done a search but cant seem to find anything. cheers Used to have a set but I sold em. Looks just like the intake when its ported. Round corners and knifed in the middle and rough texture. SP Quote
05.Banshee.SE Posted January 20, 2009 Report Posted January 20, 2009 I can pull mine out of my bike tomorrow for a pic if you want. The reeds should barely be held on, and the biggest difference will be in the height, not the width. Quote
locogato11283 Posted January 20, 2009 Report Posted January 20, 2009 anyone actually think youll really even notice any gains from this? i have no reason to believe that modifying stock cages makes a significant power increase. maybe someone has some charts, but i really doubt you will gain much if anything from this mod. Quote
278 Posted January 20, 2009 Report Posted January 20, 2009 Its actually just as good as getting VF3's. heres how you do it I used a dremel and I carbide cutting tip to do the major work, then a flat pretty coarse file to help finish shaping it up then finish it off with a triangular fine file, But you can use anything that gets the job done... with the dremel really watch what your doing so you do take to much out it works fast. so what you want to do is use the stock reed petals as a template. on the bottom and inside edge grind it down to where the petal will just barely rest on the cage maybe half a millimeter of a little less. On the outside edge just basically grind off the lip. Then ontop grind it up about 1cm. or about 2mm. below the screw holes, then reshape theinside a little to get smoother flow because you created a drop on the top part. Then I like to use the Boyesen carbon fiber dual stage reeds or the carbon flex 2-stage reeds from vito's (theyre the same thing). Those reeds will cover up any little mistakes you made if you went to far or created a nick that you couldn't grind out because of lack of material. Quote
GrMeyer Posted January 20, 2009 Report Posted January 20, 2009 I opened mine up and added pods and I couldnt be happier with how it runs now Quote
jimbob Posted January 20, 2009 Author Report Posted January 20, 2009 yeah i had a banshee last year which i put pods on and was really impressed with the throttle response, trouble is pods are really hard to get hold of here, i had to get my last set shipped from the states, its something which i will be doing again tho. Quote
tnGRbanshee Posted January 20, 2009 Report Posted January 20, 2009 i think there is some very detailed info on tony doukas site http://www.bansheedepot.com/REEDCAGES.asp Quote
278 Posted January 21, 2009 Report Posted January 21, 2009 i think there is some very detailed info on tony doukas site http://www.bansheedepot.com/REEDCAGES.asp Thats pretty much exactly what I did just not as precise on the measurements. I've had a couple friends get rid of there VF3's after I showed them what I can do... Not just on a banshee but a few different 2-strokes Quote
MDS2106 Posted January 21, 2009 Report Posted January 21, 2009 (edited) Here is a set that I was running at one time. http://www.bansheehq.com/forums/index.php?...89&hl=CAGES Better than stock but no where near vforce Edited January 21, 2009 by MDS2106 Quote
Chariot Performance Posted January 22, 2009 Report Posted January 22, 2009 Its actually just as good as getting VF3's. Then I like to use the Boyesen carbon fiber dual stage reeds or the carbon flex 2-stage reeds from vito's (theyre the same thing). Ported cages do not flow what vforce do. Vforce flow about 72 cfm if I remember correctly and the best you can get stock to flow are about 43 cfm with boyesen reeds. But that does not mean that ported cages won't work better for your setup (ask your builder). Blaster cages without porting and with boysen reeds flow about 53 cfm. Vito's carbo flex reeds are not the same as boyesen carbon reeds they are boyesen power reeds with a coating not the carbon. "Carbon Flex" is vit's name for them and it is very decieving. Vito's "carbon flex" reeds are coated so they are safe to run alcohol. That is the only difference between them and boysen power reeds. Quote
Chariot Performance Posted January 22, 2009 Report Posted January 22, 2009 Ported cages do not flow what vforce do. Vforce flow about 72 cfm if I remember correctly and the best you can get stock to flow are about 43 cfm with boyesen reeds. But that does not mean that ported cages won't work better for your setup (ask your builder). Blaster cages without porting and with boysen reeds flow about 53 cfm. Vito's carbo flex reeds are not the same as boyesen carbon reeds they are boyesen power reeds with a coating not the carbon. "Carbon Flex" is vit's name for them and it is very decieving. Vito's "carbon flex" reeds are coated so they are safe to run alcohol. That is the only difference between them and boysen power reeds. It is best to leave the center wide but carve out about 3/16 inch up off the end. Carve so that the center doesn't toubh the tip anymore. Quote
njbanshee Posted January 22, 2009 Report Posted January 22, 2009 Dont be cheap, buy the vforces. Quote
gregrob Posted January 22, 2009 Report Posted January 22, 2009 I'm running them in my duner with boyesen dual stage reeds and can't tell any difference btw them and VF2's. Spend the money of V Force if you want but for all practical purpose on a play motor, the ported cages and boyesens do great. Quote
AKheathen Posted January 22, 2009 Report Posted January 22, 2009 (edited) It is best to leave the center wide but carve out about 3/16 inch up off the end. Carve so that the center doesn't toubh the tip anymore. um, can u clarify which center and end? Edited January 22, 2009 by AKheathen Quote
