300 Mains with stock 25 pilot jets... Will this work? Seems to have no low end, and is hard to keep running. Will going to 27.5 on the pilot jets help remedy this?
Anthony
Edited by acfine
Still need info.
My Banshee is a 2002 with FMF Fatty exhaust, Core2 silencers, 300 main jets, 25 pilot jet, K&N filter and a K&N PowerLid.
Elevation is 430ft. (Dallas, TX)
Once I'm up in the RPMs, it screams, but it's really tough to get going at all with the amount of bogging...
Well im at sea lvl
and with the lid off the airbox fmf fattys and +4 timing
i have 27.5 pilots. when i had stock 25's it bogged horibly on the bottom end. put the 27's and she screams with no hesitation
so try the 27's . besides if its not that then just swap em out with the 25's. the carbs arent that hard too pull. Its worth a shot yess?
Should be pretty close. Sounds like it's asking for more air! That airfilter clean & oiled properly? Once over oiled my filter and bogged out like that because it couldn't breath!
I agree, I have roughly the same mods as you (FMF Gnarly, k&n, no lid) and I'm running stock pilots with 300 mains. No bog here at 700 ft. Check your needle setting, should be on the 3rd clip (middle one).
No, the bogging started as soon as I put the 300 Mains in, and the air filter is good and clean... I'm gonna mess with the air screw for a bit, and then go with the 27.5's if need be. I agree, swapping the jets aint bad at all, either way, I'm close, and not a lot of work left to do.
