locogato11283
Admin
Everything posted by locogato11283
  1. When you say you pushed the lever on the case, did it move or not? Is there play in it? You should not be able to move it by pushing on the clutch arm with your hand. If there is play in the clutch arm, that would lead me to believe you welded the rod and ball to the inside of the clutch shaft.
  2. I agree with dajogejr.. If you were that high up, jetted that rich and still blew it up, then you had another issue. The jetting specs I gave you are what needs to be in your bike. You just need to make sure you get your issues worked out.
  3. I told you exactly what jetting to run in the first post I made. That's not a guess. That's what you need to run.
  4. I'd run that on +4 timing. Yes, you will need to run the 100 octane for the increased compression and timing. Your jetting should be right around 160-162 main and 45-48 pilot. Are the bikes beating you straight line or in the trails? If straight line, you need to check traction. If it's in the trails, you're probably just screwed.
  5. That had less to do with swingarm and more to do with a sucky rider.
  6. I see the little Jew kid in that picture.. Probably trying to find shit to sell.
  7. Sick made!! If anyone is in Vegas and has time to meet up with Jeff, do it! Super cool guy and will talk bikes and whatever all day long.
  8. An adult diaper would be a lot easier. He gets wasted and passes out. Then we put a diaper on him.
  9. That's gangster! Nice whip!
  10. I'm glad there are some girls coming. Who else is going to cook and clean up after the guys?!
  11. I've made a lot of great posts.. Which one specifically? I didn't grope shit! Just pointed out that her jeans were ripped! You'd have better luck finding BigFoot or the Loch Ness monster. You're right.. You're like one of the bitches..
  12. That kid is a JEW!! He's a scammer through and through! Hurry up!
  13. I was fucking scared. I was sure we were all going to die. I clearly remember using JD as a human shield and saying, "this is not a good idea."
  14. 2 months and 5 days bitches!!! :headbang:
  15. 35mm PWK will not even fit in stock intakes. If at all possible, stay away from using the spacer. It is most commonly used to space the carb out and away from the clutch arm. I actually just bend my clutch arm down a little bit so that the carbs will clear. You will need a gasket between each part.. Examples.. Cylinder - Gasket - Reeds - Gasket - Intake Cylinder - Gasket - Reeds - Gasket - Spacer - Gasket - Intake
  16. JD can barely stand or speak at .15 but we are going to let him ride an LT80 in an obstacle course? Fuck it, sounds like a good idea to me!
  17. Booiiiiinnggggg...
  18. It's very easy to do with some needle nose pliers. Make sure you cover the crank case just in case you drop the clip.
  19. Awesome fight. I kind of thought that Dan might land something big once Fedor went into his wild finish mode. The guy is just too impatient. How about Meisha Tate?! That ass. Those moves. I'd hit it. Two times.
  20. Don't worry. I will hook up the people who travel the furthest.
  21. Whoever comes from the furthest distance gets a t-shirt and year long Premium Membership.
  22. BansheeHQ Vinyl Banners now in stock! Check the BansheeHQ Gear forum for details!
    1. majorcr3
      majorcr3
      Can I get a free sample for advertising for you tyler? :)
  23. Introducing BansheeHQ.com vinyl banners. These things are high quality and heavy weight. They will withstand wind and the elements. They have grommets so that you can hang them on a wall or out where you're riding. The banners come in two sizes. 4'x6" - $35 shipped 6'x10" - $45 shipped Please specify what color and size you want when you place an order. PayPal address is [email protected] 6' banners Purple - 2 New Website Address Banners
