Everything posted by Mackington
Thanks everyone!
XFR nerf bars landed today! Glad I spent the extra $ for the blue option rather than plain aluminum. Color matched pretty well!
New tank arrived! Here are some pics: Just waiting on JDS weld-in peg inserts, XFR Nerf Bars, and MX -1 Swingarm from JL Engineering now.
Upgrading to 28mm PWK's from Stock Carbs
Mackington replied to Mackington's topic in Jetting & Exhaust Forum
Finally got my jetting dialed in perfect! Plug chop verified. Fires up first kick every time now! Here are my settings: ELEVATION: 5351 Feet CARB SETTINGS: (55 - 75 Degrees Faranheight): 28mm Keihin PWK Carbs 91 Octane Pump gas @ 32:1 (Castor 927) #40 Pilot Jets #142 Main Jets Toomey Needles #2 Needle Position (from bottom) Idle Screw almost 100% in ENGINE: (CT Racing 4 mil Stroker): MX Porting by CT Racing Toomey T5 Pipes & Silencers NGK BR8ES Spark Plugs VForce 4 Reed Cages Chariot Billet Intakes CFM Aluminum Air Box (No Lid) K&N RU-0700 Filters & Pre-Chargers Hot Rods 4mil Crankshaft Vertex 66mm Blaster Pistons (22569) Vito's Hemi Head V -Pro Design 19cc Domes (Cut for 4mil crank) -160 psi per cylinder DISPLACECMENT: 396.86cc Bore x Bore x Stroke x Constant / 2 66 x 66 x 58 x .0031416 = 396.8594 Hope someone finds this helpful! -
Good to know! I set the ride height correctly last night. Excited to see the difference soon. Right now it's on a lift waiting for other parts haha. Making some changes soon! The Blue XFR Nerf bars just got delivered to replace the Alba's, I found a used blue IMS 5.6 tank to replace clear one, and I will be swapping my swingarm out. I ordered the TT / Lightweight one from JL Engineering by mistake so I've got the correct MX one on the way! More pics soon!
Now that I think about it Alba Racing set them up if that matters. Currently looking for threads on Elka initial setup for Legacy 3's.
Cool good to know! Something to do this weekend haha. Thanks!
Cool good to know! If i end up doing any brake mods i'll be sure to take pics.
Thanks man!! It's been fun but definitely not cheap lmao. Glad I took a ton of pics along the way this time. As much as I like them my tires BARLEY clear these Alba nerf bars with the -1 swing arm. I plan on getting the XFR ones soon with the heel plates since I keep breaking peg bolts and inserts on the frame haha: https://www.ebay.com/itm/182963894986 https://www.jdscustoms.com/product/yamaha-banshee-peg-thread-inserts/ Those XFR's have the extra mounting points on the heel guards to take pressure off of the peg bolts. The "pegs" that come with the XFR's are also solid steel compared to the hollow tube Alba has. We'll see how it goes! I plan on completely overhauling the frame next winter as well. Weld in new threaded peg inserts, weld in gusset kit, hack off old brake line brackets, candy blue powder coating etc. I've got a blue IMS 5.6 Gallon tank on the way as well. The clear one was cool but decals don't stick to it at all and 100% blue will look nice! Also toying with the idea of running DC conversion eventually for some better lighting and maybe some sort of info cluster with sensors. Also need to check out brake mods! I guess YFZ calipers offer better braking performance in the front and I've seen folks install Brembo calipers on the rear. More pics to come! and videos as well I promise haha.
Yea I definitely need to adjust the rear shock after installing the -1 swingarm. Fronts likely need adjusting as well. I got these new as a set valved for my weight but have yet to adjust them. Every now and again it'll bottom out on jumps lol.
I honestly was not aware of that particular mod lol. Checking it out now.
Thanks man! Agreed. I’ve had it clog on several occasions now lol
Calling this build finished! Videos uploading this weekend I hope. Anyway here is the parts list for this build: ENGINE: CT Racing 400cc 4mil Stroker Kit w/ Hinson Clutch Compnents Toomey Racing T5 Pipes & Silencers Toomey Racing Silencer Packing Toomey Racing USFS Spark Arrestors Toomey Racing Perfect Jet Kit Needles Keihin 28mm PWK Carburetors & Cable Metal Idle Screws Vito’s Hemi Head V (19cc domes cut for 4mil) Vito's Adjustable Timing plate CFM Aluminum Air Box K&N Pod Air Filters (RU-0700) K&N Pre-Chargers Chariot Billet Intake Manifolds Alba Racing Case Saver Magnetic Drain Plug VForce 4 Reed Cages Modquad Allen Stator Cover Bolts Modquad Allen Clutch Cover Bolts Pro Design Billet Water Pump Impeller Pro Design EZ Drain Cover CV4 Radiator Hose Kit Alloyworks High Capacity Radiator Tusk Water Pump Repair Kit New OEM Pump Impeller Gear JT 15/40 Sprockets DID 520X110 x-ring chain Inline Temperature Gauge Pingel Dual Outlet Petcock Pro Design 1/4" Fuel Lines CONTROLS: Pro Taper 1 1/8" Handlebars / ATV High Bend Lonestar Racing +2 +1 Steering Stem & 1 1/8” Clamp Pro Taper Grip Donuts Pro Design Tether Kill Switch Pro Design Billet Power Shifter Magura Hydraulic Clutch iOC Clamp-On Grips Parking Brake Block Off Plate Streamline 7-Way Steering Stabilizer Nac’s Racing Front Master Cylinder Cover MZS Adjustable Front Brake Lever Chariot Racing Thumb Throttle CHASSIS / SUSPENSION: Elka Stage 3 Front and Rear Shocks Elka Front Shock Guards Extreme mfng. Wide Grab bar Extreme mfng Chassis Skid Plate Duncan Racing Chrome Front Bumper Alba Racing ProPeg Nerf Bars Alba Racing Rear Wheel spacers Brake Light Lens Lonestar Axle & bearing kit Lonestar 2+1 A-Arms JL Engineering -1 MX Swingarm JJ&A Round Bearing Carrier Kit T.M. Designworks Chain Slide-N-Glide Kit JDS Customs Sprocket & Rotor Guards Lone star Brake Line Clamps Maier Custom Plastics IMS 5.6 Gallon Tank Lone star Racing brake lines ModQuad Axle Nut Cascade Innovations Light Covers Alba Racing Beadlock Rims Maxxis RAZR2 Tires + Mounting Tusk Chrome Wheel Lug Nuts Alba Racing Whip Flag Mount & Flag Seat from Custom Seats of Louisiana Rear Shock Rez Mount Billet Gas Cap Valve
Got my new Grill and Seat on today! Videos soon I promise! Found a pro track that actually allows ATVs near me
Thanks! Think I am finally done with it now. I'll definitely post videos soon!
lol crab walk is a good way to put it! Too much adjustment required on those stock swingarms.
For sure! cannot beat the price either.
Finally got my JL Engineering -1” Swing arm on today! Along with the swing arm I also installed the TM Designworks “slide-n-glide” kit and a sprocket / rotor guard combo from JDS Customs. I love how it turned out!
Yea not the best but it’ll have to do lol
Back up and running! Need to clean up the weld a bit and paint it but otherwise it’s fixed. He welded a small, solid steel cylinder over the hole about 1 inch in diameter and about an inch tall. Just tapped a hole in it for the stock steel bolts and it’s all done!
Good to hear! That one is a -1
Thanks man! I bought the slide-n-glide kit for $129 off eBay: https://www.ebay.com/itm/TM-Designworks-ATV-Slide-N-Guide-Kit-Yamaha-Banshee-350-BLUE/140624851208?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 I dig the look and the quality but I'll know more when I get it the swingarm installed haha.
So far so good! I did shear a foot peg off last week on a jump though lol. I managed to get the broken bolt out on the right side but the nut welded inside the frame on the left side broke free in there. I’m trying to get a threaded steel spacer welded in place on the left side since my nerfs require a half inch spacer anyway. Out of commission for now but will post more pics when I get my swingarm on. Waiting on sprocket/guards from JDS to do that. Last piece will be the custom seat!
Just ordered the sprocket and rotor guards from JDS customs today too. More pics soon!
Thanks man! I definitely agree John is a good dude. Great service!!
