Everything posted by Mackington
Upgrading to 28mm PWK's from Stock Carbs
Mackington replied to Mackington's topic in Jetting & Exhaust Forum
Hey Everybody! Recently tuned my carbs again and FINALLY got it dialed in 100%. I installed #42 Pilots and a JJH Needle on the middle clip. Now it idles and rips smoothly throughout the whole powerband. I suspect the Toomey needles I had in there initially were slightly too lean along with the pilot jet. Anyways here is (hopefully) my final jetting setup for my 4mil: ELEVATION: 5351 Feet TEMPERATURE: 60 Degrees Faranheight ENGINE: (CT Racing 4 mil Stroker): MX Porting by CT Racing Toomey T5 Pipes & Silencers NGK BR8ES Spark Plugs VForce 4 Reed Cages Chariot Billet Intakes CFM Aluminum Air Box (No Lid) K&N RU-0700 Filters & Pre-Chargers Hot Rods 4mil Crankshaft Vertex 66mm Blaster Pistons (22569) Vito's Hemi Head V -Pro Design 19cc Domes (Cut for 4mil crank) -160 psi per cylinder CARB SETTINGS: (55 - 75 Degrees Faranheight): 28mm Keihin PWK Carbs 91 Octane Pump gas @ 32:1 (Castor 927) #42 Pilot Jets #142 Main Jets JJH Needles #3 / Middle Needle Position Idle Screw 50% in Air Screws 1/2 Turn Out The picture attached is a plug chop performed 1st - 6th gear / Wide Open Throttle https://imgur.com/a/Xt2Jbmq -
Thanks!!
sweet!
Hahaha they are indeed! I agree they look much better off.
Here is the first lap after completing the build! I took it easy on the first lap then checked everything out. So far everything is looking good! Definitely need to adjust suspension though. I keep washing out of corners wide. Thinking the rear shock ride height is set too low? Any advice on ride height in general would be appreciated! Want to get the most out of these long travel shocks. https://youtu.be/BIOpcXSwcac
Glad I checked the clearance out again. While I was able to clear the ball joint initially by shifting things around slightly I noticed that if I 100% bottomed it out I would have ruined the rezzies! I was able to move them to the front / behind the spring and everything clears now! These PEP rezzies are huge lol. Now waiting on a damn swingarm rebuild kit of all things lol
Thanks! Love them so far haha. I can adjust them now but may move the rezzies altogether
Thanks! Yea I actually had to move the rezzies forward a bit to clear the a-arms. May mount them as remote rather than piggyback one day. We’ll see how it goes!
Nah I missed out on them ones. It was another partout on here
Here’s a pic with no shock covers on:
$500. Bought them brand new in April. Valved for 185 lbs. Was running them on Lonestar +2+1 A-Arms. Comes with the guards too
421 Serval for sale or part out
Mackington replied to BlackandYellowBanshee's topic in For Sale - Parts & Accessories
Just got my shocks! Well packaged and got here quick 👍 thanks again!! -
Update! I got a great deal on some PEP ZPS Long Travel Shocks! So the adapters on the a arms are gone and so are the Elkas. Old elkas are up for sale on the FB page.
Cool! PM Sent. Thanks! -
Hey! Definitely interested in those PEP front shocks. What weight are they valved for? Thanks! -
Pep 17” long travel front shocks
Mackington replied to nastyracing's topic in For Sale - Parts & Accessories
Interested in the PEP shocks if they're still available! PM sent. -
lol I know I know. I am considering sending ts back to have them add more foam. Love the look and the material used just not enough padding.
Thanks man!! They're amazing! Pretty damn pricey though. To be honest when these wear out I'll get the same ones my Wife runs. QuadBoss QBT tires. They hook very well and it's a steal for 4-Ply tires. All for 1/3rd the price of those RAZR2's. Can't wait for the track this weekend. Definitely need to get video!
I agree! lmao Thanks!! Clear one was cool but the blue has a much cleaner look. I found those Banshee decals on Ebay: https://www.ebay.com/itm/YAMAHA-BANSHEE-sticker-decal-quad-ATV-14-Pieces/282282949000?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Thanks!!
Thanks!! Much better than the clear one I had
Thanks!! Yea I wish I left the foam alone lol. Looks sweet though! I've got another seat I swap to on those longer rides. The low profile helps a little when dipping into the turns on a track. I swapped to those new Alba A-Arms that will allow me to switch to long travel eventually. Done putting $ into this one one for a while lol. That black Banshee is my Wife's which is also almost finished! Finishing the front end this weekend.
After waiting on a few key parts it’s finally back together!
Cool! Thanks! Glad to hear it's not too difficult. I bought the kit but will only need to use 1 for now. This winter I am considering powder-coating the frame. I'll probably do all four inserts when or if i do powder.
After some research I ended up ordering a pair of used Raptor 700 Front Calipers off eBay for $70: https://www.ebay.com/itm/yamaha-raptor-700-yfz-450-front-brake-calipers-04-18-1/173282816148?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 I also ordered Alba Racing's new Adjustable 2+1 A-Arms that can switch between standard and long travel shocks. My wife's Banshee will be inheriting my LSR A-Arms once her rebuilt Works Dual Rate Shocks get delivered. http://teamalbaracing.com/i-13568041-yamaha-banshee-350-adjustable-long-travel-a-arms-21-1990-and-up.html One thing I was unable to find on here was a write up on how to weld in these JDS threaded peg inserts. I went and bought a welder and will do a write up if it turns out OK. Been a few years since I've welded anything lol. More pics soon!!
