ClaudeMachining
    110
Everything posted by ClaudeMachining
  1. In theory, yes. You have one more layer on the cylinders. But when the engine is running the main cooling system is the coolant circulating, That's why i want numbers. How many more deg F are we talking? Sleeper said he did tests but didnt give any numbers.
  2. You gay. That align with reality.
  3. That's not an aswer. I want numbers.
  4. Do you have 'real' numbers on lc pc vs lc non pc running temp?? That's all i want to know. Likei said reality must match theory.
  5. Guys, it's not a pissing contest... I just want to know how many deg higner was the operating temp of a pc vs non pc engine. My guess is less than 5deg F. We are talking about heat transfert. A small coat of paint cant make a good running engine over temp, i dont buy that at all. Like i said, maybe on a pipe, wich is thin walled and doesnt have the same 'cooling mode' as a LC engine with thick wall and coolant circulating.
  6. Practice must match theory.
  7. I dont are about cool down temp. What about operating temp?
  8. Tyler, dont ban him, we need intertainment.
  9. Like RU said, in theory, yes, in reality? Maybe 2-3 more deg? It's not like pipes, the walls are very thick and the pc layer is very thin.
  10. Making his own stuff is fun tho.
  11. Canada's immigration servers crashed today! Lol!
  12. No problem dude. You will be the juge when you will try.
  13. Shit, i didnt know i had problem shifting with a lockup until FAST said it... That's bullshit, me and plenty other peeps are using lockup in trail with 80+ hp bike. You saw my videos, it shift pretty good.
  14. Carbs diameter is over rated.
  15. The only thing who will change in your face doing mma is your ears and usually, chick digs colliflower ears ;-)
  16. Noice! It's fun, isn't it? ;-)
  17. Noice, you would probably make a good mma'er
  18. Yes. Just google 'banshee welded crank'. Stock stroke = 54mm you can measure it. Dunno the best way to check the timing on the jugs tho... Someone else will help hopfully.
  19. Yes, you can run stock crank with big bore as long as the jugs are ported for a stock crank. But a fully stock crank is week on the pins, if you go for more hp/cimpression, you better use a crank with welded pins. Does your crank have welding on the pins??
  20. Yes. Look at my video, I shift pretty quick with ease. https://youtu.be/pk4ixrj6HNU Envoyé de mon GT-P5113 en utilisant Tapatalk
  21. This is a dl lockup The grooves are 'slopped' , the balls want to go from center to outside with rpm raising and they push on the plate 'cause they have to 'climb' the slope. More balls equal more force on the plate at High rpm.
  22. I already told him about window movie maker in the sb... Envoyé de mon GT-P5113 en utilisant Tapatalk
  23. Both have their plus/minus. Be abke to keep your oem cover is one of the 'plus' for the slingshot type. Envoyé de mon GT-P5113 en utilisant Tapatalk
