slothman
Everything posted by slothman
  1. That blows, sorry mate. I think NOW is a good time for a 4mil
  2. Not sure why you think four strokes are more "reliable" .....doesn't matter what kind of motor it is, any kind of motor can have problems If you want to stunt, why don't you get a street bike like most people ? This is a QUAD
  3. Theoretically yes because the spark will have a longer travel between the electrode. But the gap would have to be WAY off. So just gap it at .020-.028 If your Shee is missing at high RPM you might want to check out the carbs/jets
  4. r u fukin serious?. is this a joke ?
  5. LOL amen to that ! burn that fukin' warrior
  6. You can't just "guess" the pilot size. Remove the carbs and look at the jets for yourself. Every bike is going to require different jets, depending on your elevation and what mods are done to the bike. What air intake setup are you using? Any other mods besides the exhaust? What is your elevation? What color are the electrodes on your plugs? Help us answer these questions, and we will help YOU
  7. Check the domes on the slides, they should be facing the rear of the bike
  8. Set the timing to 4^ and run race fuel ....don't run it anymore until you fix the detonation problem or you will pop that motor !
  9. Why not buy a wrecked GSXR and throw that motor in it? After all, it's a crotch rocket engine, designed for a crotch rocket frame. You are going to spend a shit load of money trying to make that engine work with a banshee frame.
  10. Welcome fellow no0b ! Most of that stuff listed you can find on ebay for really good prices. If you are thinking about a top end rebuild, get the jugs mic'd and then bore/port it. Then slap in some Wiseco prolites. They sell full kits on ebay including gaskets/wrist pins/bearings etc for $200-250 They a good machine shop could bore each jug for $50 a piece, or send it to FAST or a BHQ sponsor. Good luck !
  11. I think people would be able to help you more if you had your current mods listed and what you plan for the future.
  12. Do you have aftermarket pipes? What pilot jet are you running? What main jet are you running? Are the slides rising at the exact same time when you ease into the throttle ? What is the current setting of your air screws (how many turns out) ? Also as mentioned make sure the dome part of the slides are facing the rear of the bike.
  13. Welcome aboard mate ! Just do a search on the board, and you can DL the service manual. It contains everything you need for this fix. Take your time and you will be OK as long as you have a small amount of mechanical experience. Have fun !
  14. you know the saying, if it runs good, don't fuk with it !
  15. 2 (oem) rear gold rims and tires size 20-11-9 "Titan Turf Tamer" tires Size rim is 9 x 8.5 Price is $80.00 plus shipping 2 (oem) front rims size 10 x 6 One rim has a flat spot, the other rim is fine Price is $45 plus shipping Rims and tires located in Fresno, CA. Please send me your zip code and I can get you a shipping cost. Paypal only.
  16. I didn't even know they made a B8ES lol....my yamaha waverunner also takes the BR8ES so I thought the other plug was for older model Yami's
  17. you're doing something wrong if the bolts are all the way in with a 104 chain/stock gears and still have 2" of slack. Standard slack is 0.6 inches from the middle of the chain on the top side. loosen all 4 carrier bolt nuts, and tighten the chain by turning the lower two bolts clockwise. Are you sure you have routed the chain correctly? Like this: O - - - - - O - - - - O
  18. shit.....better put the HAM radio away
  19. plan to spend $2000. lol seriosuly....you fix one thing, another thing breaks. Then you want a 4mil. Then you want a 1000000000 mil. Then you want the fastest fuckin shee in the state. lolz
  20. The slides strike again ! Glad you got it fixed
  21. what kind of fluid are you running for the tranny? Is it synthetic/detergant based ?
