special06shee
    38
Everything posted by special06shee
  1. Wow, i should ask 80k for mine.
  2. Did you try any mains bigger then 250? Pull the petcock out and make sure screen is clean. Check float level. It kinda sounds like its starving for fuel.
  3. Sounds like a super fun street car john. You might of said it before, but what kind of car is this in?
  4. Totally disagree. Price is way too high. Build me one for 1k VERY sweet frame!
  5. Ok. So they are aftermarketly installed on bangshees. Figured. Thanks for info. Pit bike most defiantly has one. Maybe 2or 3. Not sure
  6. What are shift forks? Are they aftermarketly installed. Ddq, im lost. Help
  7. If cylinders will clean up well without boring them to the moon, id keep them and invest in a nice port job. If i were in your shoes, id tear motor down, send out your crank, cylinders, and trans to redline. He can true and weld stock crank, pro mod your trans.(smoother shifts) and do a very nice port job. Youll will have a super fun pump gas trail bike.
  8. 137.00 for the big one.
  9. Gold frame with yellow plastics was a combo i always thought would look good
  10. You WILL regret running a 2-1. Dont be lazy. It takes 5-10 mins to jet per carb. Bike will run better with the duals. Why do you not like stock carbs? They are actually a decent carb and will/do work very well on MANY application including a 4m dune setup.
  11. If its gonna be a play bike run the stock carbs. If your gonna do a drag set up, buy another pwk39 to match the other.. Single carb setups are for sissy girls.
  12. Id put a 25pilot(stock size) back in too.
  13. Depends on builder.
  14. Stock jetting is 200.. Your way too big on mains.. A tight stock motor should be 120ish
  15. Good guy here. Buy with confidence.
  16. Hard to tell by the pics, but i wonder if you would switch stinger tubes from side to side if that would make it any better? From what i can see it kinda looks like they were installed backwards..
  17. Bump
  18. Nice work! Looks bad ass in roller form. Love those spindle mounts.
  19. Photoshopped.
  20. Cascade sell them with their chrome mounts.
  21. Weird. Even weirder i watched the whole thing.
