foltzman1994
Banned
foltzman1994's Achievements
  1. Do you still have the cylinders? Any pictures and do you know who ported and what type of port job?
  2. Im looking for a 4mm long rod top end. Would really like a cub but a set of ported cylinders would work too. Would like to get one ASAP. PayPal ready. I would also be interested in a set of pipes. Id prefer inframe shearer or cpi but can work with oof. Thanks in Advance!
  3. Sorry been trying to keep up with it. Everything is sold except a pair of 64.5 cylinders that have stock porting need bore
  4. Will part out engine if any interest
  5. Edit engine is actually 64.5***
  6. Have quite a few banshee parts for sale. All items will be shipped out either same day or next business day. All prices are best offer. All parts came off of a 97 Please Ask any questions Complete Motor with clutches and stator flywheel. 800 shipped came off of a running bike my compression tester shows around 120 in both cylinders. Stock porting 65.5 Painted uncut banshee plastic was originally Blue Make offer Light/Kill Switch 20 shipped Factory foot pegs 20 shipped Kick start and shifter 45 shipped kick start turns easily Factory white front shocks 50 shipped paint is not perfect Oem carbs with tors removed (one top adjuster is broke still works but cant adjust) comes with twist throttle and cable 60 shipped Toomey t5s with silencers Painted black 175 shipped complete rear brake with caliper, cylinder, line,resi, and lever 40 shipped Cdi box 55 shipped Banshee wiring harness with key 25 shipped Pro taper bars 30 shipped Factory swing arm 75 shipped bare nothing else After market skid plate 30 shipped Rear shock 45 shipped squeaked when installed
  7. I am in the works of parting out a 97 banshee. All prices are best offer. Will trade for other parts If you don't see what you need just ask I probably have it All items will be shipped same day or next business day call or text me with needs 218-849-3543 for fastest response Hot rods stock stroke crank bad PTO rod bearings are ok make a little noise on pto side 65 shipped Stock Transmission with drums forks ect 85 shipped Stator coil 55 shipped Cdi wire harness 60 shipped Complete Clutch 85 shipped Toomey t5s with silencers 250 shipped ( I will be repainting pipes before I ship) not rusted through just surface Factory carbs, intakes, reeds, and boost bottle. Has tors remover and twist throttle( One cap top is broke see pic) 80 shipped
  8. Still have cylinders? Call or text me 218-849-3543
  9. Hey im looking for a 4mm stock cylinder would like drag ported but let me know what you have. Call or text me 218-849-3543 Thank you
  10. Update: stock cylinders sold Head sold 34mm carbs sold Swing arm sold Will sell stock carbs for 70 shipped with cable intake boyesen reeds stock reeds intakes and boost bottle I put a new bearing on one stock crank shaft all other bearings and rods are nice yet will sell crank and stock bore ported cylinders with head and two pistons for 400obo shipped Also have a set of factory head lights. just the ring and lens 15 shipped 450 shipped for everything Thanks Hunter
  11. I used factory nuts on it. It will need o rings and good to go.
