special06shee
    38
Everything posted by special06shee
  1. http://www.bansheehq.com/forums/index.php?/topic/176437-421-cub-%2C-duner-complete-part-out%2C-redline%2E%2Eelkas%2E%2Ejds%2E%2E%2E%2E
  2. Fresh Super low hr motor that runs damn good. Glws!
  3. If that was steel, it would weight 80lbs.
  4. Pull the side cover and flywheel. It would take 10mins to see if there is a problem. If all looks well, borrow a OEM cdi from a buddy and try that.
  5. It is a bad cdi. Guy i know had a cheap china cdi and it did the same thing.
  6. a few? Ha. That place is filled with people that dont have the pass, break laws, and are total scum bags.
  7. Or without tires. Literally.
  8. My stock cylinder with upp's and pwk35's hit as well. I just milled the bowl drain down to get the clearance. Fyi, yours are pj's
  9. I had to have mine pressed out. Fucker soaked it oil for 3days and still wouldnt budge.
  10. Nice! That motor runs damn good!
  11. Nice work! They are gonna be like new.
  12. My shearer small bores leaked from the orings right out of the box.. All i did was ordered 4 OEM orings. They are bigger then the ones that shearer uses. I took some emery cloth and sanded them to fit snuggly into the flanges.. (They will not fit w/o sanding) No more leaks and no messy sealer.
  13. Off 2006. I also have a key switch. If hp2000 doest have them, ill sell these
  14. The seal will offer a bit of resistance. But on a trail bike id say they are a must. You do not have to kill the nut. I always just tightened it until i had no play, then killed the jam nut.
  15. There was a fast lt80 there last yr. cant remember whos it was.
  16. From what i remember i always had little residue of fuel in my carb boot when i ran a box. If your jetting issue is down in the lower rpm range, lean out your needle and try that before you change mains.
  17. Haha. Mike and i started off only using logs (strategically placed) as ramps. Good times.
  18. Tyler is a professional stunt coordinator.. He also gives great inspirational advise before take off.
