BAMF87
Everything posted by BAMF87
  1. So you think Ill need to split the cases again and re seal them?
  2. Hi, I have a 97 banshee that I just fully rebuilt and powdercoated and everything. Took the engine apart and replaced crank seals and put all new gaskets everywhere. I've only had it out twice since the build and somehow riding "topped out" one of the spark plug boots came off and the it flat out died. When I stopped coolant was coming out of the case where the trans sprocket is on left side, also when I pulled my carbs off I can see coolant on my reeds. Any idea what may have happened. I'm hoping its just the cylinder gaskets.
  3. My 07 6.7L CUMMINS. leveled 35" toyo mt's, all deletes, mp-8, H&S XRT.
  4. I need some pod filters that fit stock carbs let me know what you have. Thanks.
  5. I need some pods for my shee that fit on stock carbs let me know what y'all have. Thanks.
  6. I need some pods for my shee that fit on stock carbs let me know what y'all have. Thanks.
  7. Pics of the albas are in the images forum, 97build
  8. I got my albas in the mail too bad I don't have my frame to mount them, the frame should be back from the powder coater on Monday.
  9. I just ordered my alba arms. ill post pics when i get them
  10. Ok thanks for the info I'll post pics in the next few weeks when everything comes back from the powder coater.
  11. Ill probably order the alba arms. when im done with my build ill have all the pictures in the images section
  12. I will be ordering one of the two on Monday and need opinions on which would be better. I'm on a budget and can't spend over 400$ on arms or else I won't be able to finish the build for like three months.
  13. So ur saying these arms with lt shocks are about the same as the +2 fullflights with st shocks? I was going to order ace fab arms or fullflights, then decided on these albas now I don't know what to do lol
  14. its hard to see them with the bumper, but how do u think they compare to your full flights?
  15. can you get some measurements to see the difference between the fullflights and the alba's?
  16. Ok thanks so much for that idea
  17. Im doing a full rebuild of my bike on a tight budget and I have some works triple rate shocks for my banshee. Will yfz a arms work with these shocks or will it be too low? if anyone has pics it would help. I was planning on getting new arms but after tearing into my motor most of my money will go there.
  18. Does anyone have pictures of their banshee with +2 a-arms with a stock length axle? I'm doing a rebuild and I won't be able to afford an axle for a few months. Id like to see if it will look weird running the stock axle for a while
  19. Ok I'll call them up and get the parts ordered any idea on what they cost?
  20. I have a 97 banshee that I'm doing a full rebuild of and I'm about to send it to the powdercoater. I'm putting the stock swingarm back on so what do I need to do about the bearings on the front of the swingarm and carrier bearings? Do they need to be removed before sending to the powdercoater? Should I replace all of them? If so where do I get the parts I need?
  21. They have an adaptor to be able to run regular shocks or lt shocks. They look awesome I was about to buy some ace fab arms but these are making me think twice!
  22. Ok thanks guys I'll see what I can afford. Any idea where to look?
  23. Yesterday I touched one of the plug wires while it was at idle and I got shocked. I'm assuming I need new wires and boots but can I replace just the wires and boots or do I need a new coil and wires? Either route what brands are good and who has the best prices?
  24. Ok thanks I'll cut that off am ditch the spacers
