ban421shee
Everything posted by ban421shee
  1. Buy the one 100% designed and 100% made in the USA and you'll have 10 more horsepower.
  2. My first Banshee had the original FMF gold pipe, they was a little better than FMF Fatty and T5's before and after porting.
  3. Didn't you win the stock swinger class and the 5000 KOTR money.
  4. I thought the King Of The River races down at Whitefield was a good indicator to how the pipes stack up in the real world!
  5. It's been my experience the shape of the exhaust port dictates the reliability of the engine. OEM cylinders with wide, square exhaust ports will catch the rings, A wide squared off exhaust port on a Cheetah Cub/DM will take out the intake bridge eventually. A cheap Chinese crank with the 29L rods have no reliability at all. It's best to use a builder, they will sell parts that are reliable and known to be good, along with port jobs that will last a lifetime.
  6. They look a lot like the T4's I had, T4's made 68hp on my stock stoke and bore engine.
  7. What was you looking at? LED's come on 700ish rpms earlier. Awesome.
  8. The Redline Servals have been peaking around 9900-10000 with Sniper and Shearer pipes, different porting on this engine?
  9. Runs 11 and 13 LED Runs 6 and 8 Sniper
  10. Why are you making all new stamps when you already have dies and stamps made?
  11. Twister cylinders have a bolt on flange made of thin steel tubing, my flanges are 43 millimeter ID. My 10 mill DM was ported by Mccoy, it made 140 with 43 millimeter ID exhaust flanges. My builder would not waste time putting a big flange on a big Twister cylinder when the head studs block off the triple ports.
  12. Just want to make sure I understand the new pipes, My stock bore stock stroke (350) gets the same pipes as my 7 mill bigbore Twister (568)?
  13. My pipes are for a 4 mill engine. 1-1\16 is one size smaller than my Shearer pipes.
  14. I've had OOF and in-frame Grand River pipes on my bike, both caused my engine to overheat severely. The in-frames came with Pro circuit tailpipes and silencers and the OOF's had 7\8 OD stingers. I had both pipes on the dyno and had been tuned to 13.5. My engine never overheated again after I put Shearers on it. Don't Pro circuit pipes have a 7/8 OD stinger and tailpipe too?????? I don't think he understands that a 4 mill 73 bore engine puts off a lot more heat than a 4 mill 64 bore.
  15. I stopped running my GGR OOF drag pipes with 7/8 outside diameter stingers when my pistons overheated and cooked the oil under the piston crown and seized the wrist pins. Why do use 7/8 stingers on drag pipes when all other pipe builders use 1-1/8?
  16. You're just mad cause you got your butt kicked by them Snipers! What happened when you raced some of them Snipers @ LSOK? Pony Express was your bike right?
  17. Not sure if its a Serval or Cub, I thought he had a DM.
  18. GOAT is said to have dyno tested Shearer, CPI and Sniper at Dunetoys on his cast 421 this week, the results have not been posted yet!
  19. The world record in the 10 mill cub class is 3.73, how do you not have the record if you ran 3.71?
  20. Your wrong, he did a product review on May 8 2012.
  21. Well , the facts are Sniper made 113.46 horsepower and the most Shearer made was 110.04 horsepower on that engine. Now put a spin on that!
  22. Yea and so have we, Sniper pipes made 3.4 more horsepower. You can twist it around anyway you want, Sniper pipes made the most power on that engine period. ha ha
  23. That badass sound is the sound of something tuned, a deep bass sound with a hit like no other pipes.
  24. Only in your dreams ROCKETMAN.
