x2 on the lower shock mount. Almost ALWAYS the cause of front STOCK end squeaks. As for the rear, I've rarely heard a stock banshee swingarm that DOESN'T squeak. Probably the same issue as the front end. Pull the shock, and grease the the sleeve. Also the linkage will have two zirk fittings, on the small part of the link. Grease those bad boys up, and if it still squeaks, screw it, you can't hear it when your wide-effing-open.
You described it as a creaking, though... not a squeak. Fox floats don't use rubber bushings, they use heims, with misalignment spacers. Those won't squeak, unless they are REALLY worn out. So I would suspect that it's your upper and lower arms, where they mount to your frame. You will find Zirk fittings on the arms themselves, grease em up. If it's kind of a grinding noise, you might have some grit between your brake pads, and rotors... compressed air or a can of brake cleaner should take care of that quickly.
