amstall
Everything posted by amstall
  1. Mine makes that same noise, I dunno if I'm just paranoid or if it's something going bad. Mine is in temporary retirement until I get the money for a serval motor. I guess I belong on YFZTech this year. lol
  2. Yep. Try syncing the carbs, takes 10 mins and its really easy....this'll help
  3. From my experience the straight paddles are a little harder to get started going sideways, but once you get them going they snap right out there. Plus they do give you a lot better push on the straight runs. I liked the haulers that I borrowed for a couple trips over my sand stars, that'll be my next set of paddles.
  4. Nice looking bike man. You'll learn more on this forum than you ever thought there was to know about banshees. It's a great site. Congrats on the buy.
  5. x2. Just search ebay for ventureshild or scotchgard film, they're got a bunch of different shapes and sizes.
  6. Crated NOS 1986 Honda ATC 250R (*Complete PARTS ONLY) Vintage OEM Hondaline http://www.ebay.com/itm/Crated-NOS-1986-Honda-ATC-250R-Complete-PARTS-ONLY-Vintage-OEM-Hondaline-/110775289109?pt=Motors_ATV_Parts_Accessories&vxp=mtr&hash=item19cab8c515#ht_9962wt_114
  7. i dunno if i can make it before winter or not but i'm definitely down. i'm always up to check out new parks
  8. 16' long should be plenty. We've put 4 quads on a 16' car trailer several times. Enclosed should work too, as long as you're wide enough u can get them turned sideways. All of our quads are wider than stock, it's tight but they fit. I'd recommend longer than you need though, so 18' or 20.....leaves room for camping gear and firewood.
  9. my 2 'shees are sitting here waiting on ya. lol
  10. gonna have to miss the HQ ride.....damn
  11. Here is a list of what the extra bike comes with: Frame -Vin JY43GG0385C059247 (yr 2005) -Broke and rewelded grab bar mounts -1 Rear Fender Mount missing -Heal Cup mount missing -Rear Shock mount has been rewelded -Chain roller included Motor The crank is siezed but the output shaft spings freely. The lower case half is cracked on the clutch side, and the upper on the stator side( dry area, doesn't effect anything). The cylinders have been bored once (20 over) Clutch side cover is missing. The cylinders alone are worth almost $100 on bansheehq.com -1 Good head -1 Head damaged dome one 1 side FMF Fattys -Surface rust -No dents or dings -would be perfect if powder coated 2 Complete clutches -basket -inner basket -pressure plate -disks Swing Arm -Needs rewelded A-Arms -1 upper bent -ball joints appear to be good Front spindles Front Rotors Tie Rods (not bent) Front shocks (condition unknown) Rear Shock (told it was blown, never used personally) 2 TORS Kits Stock Headlights Kicker 2 Rear Sprockets -1 good Sprocket Hub Front Sprocket Chain (condition unknown) Rear Rotor and Hub Pivot Bolt Chain Tensioner Bearing Carrier Axle Nuts All Radiator Hoses Coolant Bottle Shift Lever rear Brake Lever Lower Front fender mounts Pegs & Heal Cups Rear Brake light switch headlight/run switch cluster Thumb Throttle Coil and Plug Wires 2 front calipers w/ pads front brake lever front stock bent steel brake lines Front Brake T- and Hose Rear master cylinder, Caliper, Resivoir, and pads Stator Cover -Cracked 2 Stock Carbs (1 L, 1 R) Oil filter cover Kick Gear 2 boost bottles 2 reed cages w/ reeds 2 intake boots -1 cracked radiator Air box w/ 1 into 2 boot Gas tank w/ petcock asking $1000, make an offer. Message me with questions
  12. All depends on your elevation and the compression you're making. I'm running 21cc domes w/ +4 on the timing plate on 91 octane fuel. I'm about 1200 ft above sea level.
  13. it's not that big of a deal. just drain and replace your oil and run with it. if you're real worried about it change your oil run it a bit, change it again then it'll be good for sure.
  14. did I miss the date??? or when is it. Might be able to wrangle up 8 or 10 guys from KC to head out.
  15. are the cushions even servicable? i know i need new ones but hate to drop the cash in a basket if i dont need to
  16. Anybody?
  17. Pm me with pics and a price
  18. I need to know how long the stock silencers are from the front of the pipe to the rear mount. Might be interested in buying a set too if the price is right
  19. Too bad it's not next weekend so we coulda brought out our 3 'shees.
  20. 40:1 works great if you get the 32oz jugs. Use half in 2 5 gallon cans, then throw it away. It's pretty great.
  21. We always stop at the super wal-mart in Alva or Enid, that way you don't have to worry about stuff staying cold so long. You can get pizza at both gas stations and the pizza place. There's an old school soda fountain/t-shirt shop in town. There's also a burger place in town, a burger shack at both campgrounds, and millers (breakfast and lunch buffet) but I've never been to any of them. There's a small grocery store in town but they don't have much. How much are the reserved sites?
  22. i'm sure andrew3160 and i will be there.
  23. Like it says, anybody that has one (like the one below) please chime in. I'd appreciate the info. http://cgi.ebay.com/ebaymotors/Yamaha-Banshee-Front-Bumper-and-Rear-Grab-Bar-Combo-_W0QQcmdZViewItemQQhashZitem2307203b2bQQitemZ150443408171QQptZMotorsQ5fATVQ5fPartsQ5fAccessories#ht_3858wt_1165
  24. graduation day!!! 5 years comin
  25. FMF's aren't bad at all for a stock bike, when you start getting more motor...then you can look into something else. I'm happy with both sets of mine though
