06bluebanshee
06bluebanshee's Achievements
  1. Ok thanks for the help. I will try all of your suggestions when the weather gets nice.
  2. Did you ever figure out exactly what was the cause?? I'm having the same problem as you.
  3. I just rebuilt my top end. First time starting since rebuild engine fired up right away. The right cylinder was not running as hard as the left one? The right one was firing but not real strong? I took carb off and cleaned it real good. Slides are in right and choke tube on. Bike runs good on the trails, but doesn't have same pressure coming out both exhaust pipes? Any ideas why?
  4. Hi guys I have a Banshee with: PC Pipes, VF3 Reeds, K&N clamp on Filter, No air box lid, stock pistons and cylinders. 800 feet above sea level. I'm wondering if a Noss Cool Head with 20cc domes would give me anymore power??? I know it will raise the compression and probably run cooler. But will it make anymore horsepower? Thanks for the help guys!
  5. That makes perfect sense!! Thank you!!
  6. Hello guys! What does it mean if your spark plug has a good size black burn mark right at the top of the spark plug? On the teriminal nut, the part the rubber boot slides over.... When I look at the inside of the rubber boot the metal tab has the same burn mark?? Normal or what? Thanks!
  7. Pro Circuits are some mean ass pipes!!!!! I love mine!!
  8. Thanks Robert! It's a huge power gain over a stock motor tho.. right?
  9. I have PC pipes and VF3 reeds open air box. Which port job do I want to match my pipes? I ride dunes and mx track and trails. Dune port or MX for PC pipes? Can anyone chime in with info. Thanks!
  10. I want to buy a Tors Elimation kit, but which one is best? Vito's , Motion??? Anyone has anything bad or good to say about either one? Thanks!!!!!!
  11. ok ... one knob controls both carbs? sorry I've never screwed with the tors at all.
  12. How do I adjust my idle with the TORS still on the carbs? Idle is a little low. Thanks!
  13. Thanks everyone for their input and suggestions. Much appreicated!!
  14. My friend has a 2000 blue banshee with about 5 tanks of gas run through it, bone stock and mint condition. It's about a 9.5 out of 10. Never touched. Original owner has 2 keys manual and all paperwork from new. Is it worth $3500 ??? Let me know what you guys think. Thanks.
