Drewski
Everything posted by Drewski
  1. I just mounted mine in this thread. http://bansheehq.com/forums/index.php?showtopic=128472
  2. Not the greatest picture and the rubber is dirty, but you get the point.
  3. Yep. You can't see shit for wires on my bike now!
  4. I've also heard about the interference issue from running it off the stator and from using resistor spark plugs. I will use the same BR8ES plugs I've always used and I've mounted a 9V battery to power it. It will work fine.
  5. I ended up going with the GB relocation bracket. It does not relocate the bottle but it does relocate all the wiring. I personally like this design a lot but other seem to think it will get too hot there.
  6. Right on, Nice quad! Don't under estimate that thing, They will run against a Banshee without a problem. There's also a ton of after market for them. A renegade would be my first choice for a four wheel drive quad.
  7. Thanks for the kind words everyone. I haven't had the chance to set it up yet, as the bike is still missing the motor but Installing the sensors were a breeze. For 100 bucks I think it's worth it. I was origionaly going to have the stainless lazer or water cut but it would have cost too much to have it programmed into the computer. I just took the vapor apart , traced it out onto the stainless, drilled it out and cleaned it up with carbide burrs. It turned out better than expected. If the glare is to much as to where it's affecting my visibility, I'll have it powder coated.
  8. * Speedometer: o Current Speed o Maximum Speed o Selectable MPH/KMH Display * Tachometer: o Real-Time RPM Bar Graph o Numeric RPM Readout o Dual Programmable Shift Lights o Up to 20,000 RPM * Temperature: o Ambient Temperature o Engine Temperature o Dual Programmable Temp Lights o Exact Model Fit Temperature Sensors o Selectable °F/°C Display * Distance: o Adjustable Distance o Permanent Odometer o Selectable Mile/Kilometer Display * Clock: o Hour Meter o Stop Watch o Ride Time o Accumulated Ride Time o permanent Hour Meter o Selectable 12/24 Hour Display * Power Input : o Includes Power Connection Fits All Machines o Accepts Any Power Input - AC/DC o Auto Switch to Internal Power if External is Removed o Permanent Memory Guarantees Data is Never Lost * Value Added : o Custom Designed for Exact Model Fit o All Parts Included to Complete Installation o One Year Warranty o Unlimited Free Trail Tech Phone and Email Support o Waterproof Connections Included o Bright White Backlit LCD Display o Accessory Dashboards for Most Applications
  9. looks a little better now!
  10. Use a BFH. that's all I used on my frame before the rebuild and it's straight as an arrow now.
  11. I think he means RODS.
  12. it reads the water temp. It comes with a temp sensor that you mount in the radiator hose.
  13. Iginla passes to Croby, he shoots, he SCORES!!!!!!!!!!!!!!GOLD lol
  14. I came up with a different way to mount my vapor. this is just my old bar pad from my other set of protaper contour bars that I hacked up for mock up. I'll be getting a piece of mirror stainless steel laser cut to the shape of the top of the pad and the shape of the computer just to clean it up. What do you think?
  15. I decided to run my Avenger swinger but I will be getting a piece of UHMW machined to mount to the skid plate. It's not that big of A deal.
  16. There you go dirty. Now show them what can happen in the trails! Ya, you know the vid!
  17. Your kidding right? Skipping water ain't shit to do. If I can do it on two wheels, anyone with big enough balls can do it on 4. Besides, are the dunes the only place you can find water to skip? Didn't think so.
  18. I'm sorry. I just read the email, and he says you only need them for +5- +6
  19. Well WTF? Lets go beat him up! But really, shouldn't it have a guide?
  20. I just looked at my Stock length Avenger and it too doesn't have the mount for the guide. I Emailed Edwin From Avengeratv and he's telling me that the slider won't work on the shorter round house swingers and they only use them on the +4s and up because of the angle?????? Should I be running this. He said I was jumping to conclusions when I said It needed a guide.
  21. here you go. Read this. http://bansheehq.com/forums/index.php?showtopic=73599
  22. Agreed. Therefore taking more SKILL to ride!
