robert0762
Everything posted by robert0762
  1. I need a set of bored, ten mill cases
  2. So I am in the process of building a 10 mil super serval. I dont know much about ten mil motors. When I trench cases they may have to be epoxied ? If there is a thin spot it may break through and have to be epoxied ? I def want my cases powdered so if it wont stick to epoxy guess Ill have to get em welded
  3. Just trying to get some info . Can you powdercoat cases that have been epoxied? Also does the epoxy last forever or would it need to be redone eventually?
  4. My 10 mill super serval Im in the process of building is gonna be amazing. Cant wait
  5. ill take plastics pm me paypal info
  6. ill take case saver send pay pal
  7. Any one else got some input
  8. That's the good one and its just on there for comparison. Tz bearings slide on and off . Even if I flipped it the inner race does not move and is still in the same position
  9. Picture one is how I have always seen the gear located once it is put on and when you torque it down it holds pressure on the waterpump drive gear also. Picture two . If you take notice the inner bearing race is even with the outer one pic three. On this crank the inner race is not even pic four. Since the inner race is not even the bearing slides closer to the web. I have never seen this. Has anyone else? The problem I have with this is that the gear sits back past the step on the crank. So now when I torque it down the water pump gear bottoms out on the step and does not apply pressure to the drive gear. The drive gear actually has a couple thousands of play to slide back and forth. I know that can not be good. So has anyone seen a bearing come like that ?(with a small inner race) The bearing is good . Can I put something in there to space it a lil bit? Should I put a new bearing?Will this cause alignment issues with the basket gear?
  10. I do have them one is good the other I damaged once it was out. They are original stockers
  11. Hjr hardcore mx port was designed to match the pc pipes . That's what kev told me when I got mine. I love it but the never ending hunger for more has taken over once again. So now I am building a 10 mil super serval.
  12. You think they would be a good tire for the coal hills?
  13. I just got a set of vforce 3's and i got a question. What is the square spacer plate or stuffer whatever its called. Exactley what is it for where do i use it and how do i install it?
  14. Just picked up an x33 axle off ebay with the hubs for 90 bucks. Now I gotta find a axle nut anyone no where to find one
  15. I got a set of stock bore and port cylinders. They seem to be in great shape I never ran the motor when o got it. Pics coming soon. 250. Shipped Front calipers and lines. 70 shipped
  16. I got a set of stock bore and port cylinders. They seem to be in great shape I never ran the motor when o got it. Pics coming soon. 250. Shipped Front calipers and lines. 70 shipped
  17. I need a pto nut washer and gear. The gear itself can be junk I just need the flat surfaces that seat on the bearing and nut to be good. Please include a price shipped
  18. Wrong section
  19. So i just got a 10 mil billt crank off of ebay. guy says it is a twister but there is no markings on it. I get it today take it out to look at it and the threads on the pto side have been stretched . They are not horrible but I dont feel safe with it . Can this be repaired or does it need a whole new pto web ? I got a good deal on the crank but if its a 4-5 hundred dollar repair i mite as well just go buy a new one . Crank works said they wont rethread it just put a new web wich is 350 dealer price.
