ok lets test the coil so we can rule that out. there is no way to test the cdi unless you get a known working one. i would try the coil first. if your coil is bad i have an extra one for you. 15 bucks plus the ride
Unplug the orange and black wires from the wiring harness to the coil, and pull the spark plug boots off the spark plugs, then use a 12mm wrench to remove the coil mounting bolts. To test the coil, use an ohmmeter to first measure the primary side resistance between the "+" and "-" terminals that connect to the wiring harness, you should have between 0.28 and 0.38 Ohms. Next test the secondary side resistance between the "-" terminal and the connector inside EACH spark plug boot, you should have between 4,700 and 7,100 Ohms in each one.
